1 members (Southerntruck), 73 guests, and 2 robots.
Topics128,049
Posts1,055,635
#1505642 06/17/2023 4:11 AM
If anyone has installed an under-bed fuel tank, I'd love some pictures or ideas. I need a larger tank so I'm pulling the in-cab tank out. I plan on saving it just in case my kids or a future owner wants to bring it back to original later. I'd love a large tank, between the frame rails.
1961 C60 2T Flatbed (former rural brush fire truck)
283 V8 - 4spd - 21K Miles - 2spd Rear - 2WD - PTO
Fosterelli #1505646 06/17/2023 9:13 AM
I have a 20-gallon on my 54 and ran the filler out the top of the left fender. After I installed the filler the company came out with one that was a locking one but it did not fit the filler hole I already have. The name escapes right now. Sometimes I regret it because it makes it a little tail heavy but I like the inside storage where the old tank was.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Fosterelli #1505649 06/17/2023 10:20 AM
7
7 Offline
Fosterelli, there are a number of big truck tanks available for frame mounting, square and round, most mount on the outside of the frame rail.
Fosterelli #1505754 06/18/2023 3:44 AM
R Online: Content
I assume this is for a Big Bolt and not a pickup?
My '47 has a rectangular shaped tank mounted outside the frame rail. One of the gallery pictures shows it, although it's not a real close up. If need be, I can check and see if I have a better picture of it.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Fosterelli #1506719 06/25/2023 5:55 AM
Thanks, y'all. Correct, 1961 2 ton flatbed dually big bolt.
I'm trying to stay inside the frame if at all possible.
Fosterelli #1506722 06/25/2023 7:27 AM
One interesting tidbit from my hours of online searching. A lot of manufacturers & retailers list 1955-1959, and 1963-1970, completely skipping 1960-1962. Anyone have any information or guesses on why this is the case?
Fosterelli #1506733 06/25/2023 1:28 PM
3B Offline
Hy Fosterelli, the only thing I can think of, is that the 1960 through 62 trucks used a different front suspension system, torsion bars instead of leaf springs. This will make the frame different where the torsion bars mount, but I wouldn't think that would effect the installation of a frame mounted fuel tank.
3B #1507179 06/29/2023 1:11 PM
Thanks, 3B. I've given up for now. I had ordered a tank off Amazon but the fit wasn't exactly what I was hoping for, so I returned it. I'll keep moving with the other parts of this project and circle back to the fuel tank later!
Fosterelli #1507207 06/29/2023 3:52 PM
I will say my 67 c50 came with 3 tanks 2 saddles and the in cab tank but when I got it it only had the in cab tank. It has a splitter valve that is on the floor but it has of course seized up but for my truck I am doing it as cheap as possible so I actually bought a 18 gallon boat tank and installed it on the side of the frame. At some point I am also going to be cleaning out the in cab tank to use with the saddle and do some electrical wizardy and have a switch and a relay to run to the fuel gauge and a solenoid valve. But if you just want the in frame fuel tank I know late 90s 1 ton fords you could get a 40 gallon tank in them so might be worth looking into.
1967 Chevy c50 327 w/ sm465 5000Ib front 15k 2 speed rear w/ 22k springs, single axle, hydraulic brakes
Fosterelli #1507397 06/30/2023 10:58 PM
Thanks, Thick Chevy, I'll look up the Ford option and take some fresh measurements against it!
