| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2023 Posts: 25 'Bolter | | 'Bolter Joined: May 2023 Posts: 25 | If anyone has installed an under-bed fuel tank, I'd love some pictures or ideas. I need a larger tank so I'm pulling the in-cab tank out. I plan on saving it just in case my kids or a future owner wants to bring it back to original later. I'd love a large tank, between the frame rails.
1961 C60 2T Flatbed (former rural brush fire truck) 283 V8 - 4spd - 21K Miles - 2spd Rear - 2WD - PTO
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I have a 20-gallon on my 54 and ran the filler out the top of the left fender. After I installed the filler the company came out with one that was a locking one but it did not fit the filler hole I already have. The name escapes right now. Sometimes I regret it because it makes it a little tail heavy but I like the inside storage where the old tank was.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | Fosterelli, there are a number of big truck tanks available for frame mounting, square and round, most mount on the outside of the frame rail.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I assume this is for a Big Bolt and not a pickup?
My '47 has a rectangular shaped tank mounted outside the frame rail. One of the gallery pictures shows it, although it's not a real close up. If need be, I can check and see if I have a better picture of it. | | | | | Joined: May 2023 Posts: 25 'Bolter | | 'Bolter Joined: May 2023 Posts: 25 | Thanks, y'all. Correct, 1961 2 ton flatbed dually big bolt. I'm trying to stay inside the frame if at all possible.
| | | | | Joined: May 2023 Posts: 25 'Bolter | | 'Bolter Joined: May 2023 Posts: 25 | One interesting tidbit from my hours of online searching. A lot of manufacturers & retailers list 1955-1959, and 1963-1970, completely skipping 1960-1962. Anyone have any information or guesses on why this is the case?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Fosterelli, the only thing I can think of, is that the 1960 through 62 trucks used a different front suspension system, torsion bars instead of leaf springs. This will make the frame different where the torsion bars mount, but I wouldn't think that would effect the installation of a frame mounted fuel tank. | | | | | Joined: May 2023 Posts: 25 'Bolter | | 'Bolter Joined: May 2023 Posts: 25 | Thanks, 3B. I've given up for now. I had ordered a tank off Amazon but the fit wasn't exactly what I was hoping for, so I returned it. I'll keep moving with the other parts of this project and circle back to the fuel tank later!
| | | | | Joined: Apr 2022 Posts: 81 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 81 | I will say my 67 c50 came with 3 tanks 2 saddles and the in cab tank but when I got it it only had the in cab tank. It has a splitter valve that is on the floor but it has of course seized up but for my truck I am doing it as cheap as possible so I actually bought a 18 gallon boat tank and installed it on the side of the frame. At some point I am also going to be cleaning out the in cab tank to use with the saddle and do some electrical wizardy and have a switch and a relay to run to the fuel gauge and a solenoid valve. But if you just want the in frame fuel tank I know late 90s 1 ton fords you could get a 40 gallon tank in them so might be worth looking into.
1967 Chevy c50 327 w/ sm465 5000Ib front 15k 2 speed rear w/ 22k springs, single axle, hydraulic brakes
| | | | | Joined: May 2023 Posts: 25 'Bolter | | 'Bolter Joined: May 2023 Posts: 25 | Thanks, Thick Chevy, I'll look up the Ford option and take some fresh measurements against it!
