3 members (Gdads51, UtahYork, 1 invisible), 109 guests, and 3 robots.
Topics128,191
Posts1,057,364
Members48,469
62 C10 235 ,3 speed, 1 1/16" bore slave cylinder..
Looks like I can just hone it and replace the 2 seals. Put the snapring back in and re-install.
Where can I get these seals ?
Google just shows me complete units for sale.
1962 C10 with a 235 6cyl -- all of the drive train seems to be original.
Some of this story is in the Side Lot
Some people like a new truck. I liked the old ones.
Fattboyzz, contact Dixie Bearings in Austel/Lithia Springs.
They've helped me in the past with oddball O rings and seals when they were located in Doraville. I took my old stuff in and they matched them up.
Looks like they're merged or something with Applied Industrial Technologies
Dixie Bearings
1515 Distribution Ct, Austell, GA 30168
(770) 745-5504
1525 Distribution Ct, Lithia Springs, GA 30122
(678) 398-3185
1950 Chevrolet 3100 (Ol' Roy)
Thanks. I will give em a call 👍👍
If you do get some info or sizes come back and let us know. I have replaced 2 slave cylinders and would prefer to rebuild if I can.
~ HB
1962 Chevrolet C10
1962 Suburban
Riding in the Passing Lane
Any parts store can supply a kit for those clutch cylinders. Its a good idea to put a kit in the clutch master cyl. also. Get a brake cyl. hone & run it through the bore a little. Clutch cyl. rubber parts wear out sooner then brake parts. They make a full trip of the cylinder each time they are used. The brake cylinder cups don't move much, they just apply pressure.
Consequently the bore in the clutch cyls. do not corrode like brake cyls do.
George
1972 Chevy c10 Cheyenne Super
The dual purpose master cylinder is new. The old one was so coroded ,it was pretty much welded together . Rear wheel cylinders too frown
Im gonna rebuild the original slave cylinder when I get time.
I dropped a part return off at Autozone and grabbed a new slave cyl.
They said no carry on a rebuild kit frown
