2 members (farmallb, 1 invisible),
181
Mod | | | Forums66 Topics128,087 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Looking to convert my 70 C50 to power steering. Any one know what boxes fit other than the 67-72 medium duty trucks? does the steering box only fit the medium dutys? not too many yards here that have any older stuff around especially meduim dutys. Thanks
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Is the power steering in the box like a regular truck? or is there a external ram that adds assist? someone said that it's not in the box, these trucks had a external ram that added assist?? looks like a large steering damper connected to a power steering pump. does this sound correct? If so does any one where I can get this set up?
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've got a regular pick-up steering box on my 48 1 1/2 ton. I think it came from a '78 Chevy 4X4 3/4 ton. I don't have any problems at all, and I even run an 8' plow on it, Scott | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Did you have to do any modifications? pitman arm/drag link must be different?
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Oh yeah, but that was on a 48. I'm not sure how your C50 box is set up. I'm just stating that my steering box is heavy enough for my big truck. I'm not sure if you'll need a standard pick-up box or a 4X4 box for your truck, Good luck, Scott | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Yes the power steering for your truck is a power assist ram. However the control valve is in the box so you will need the box ram hoses pump and linkage for the ram attachment. This system works much better than most power assist setups. Because the valve that controls the ram gets its input from you at the boxes input shat instead of from the box at the draglink. This gives much better road feel much like a standard power box. This box will look like a normal Saginaw box but the output shaft is horizontal like your stock manual box instead of vertical and it has four ports instead of two. An input a return a left turn and a right turn port. | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Thanks, The problem is finding these parts. these trucks are few and far between around here. Any one got any trucks they are parting out?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have a box from a 78 GMC 6500 that may work. I was considering using it on my 48 in place of my IH Scout box, but with my diesel and other goodies it would not fit. It may fit your truck nicely? Can you post a picture of the original setup? Grigg | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | I'll try to get a picture of the set up
