3 members (Lostbuthaulinass, MNSmith, festerhairball), 99 guests, and 2 robots.
Topics128,057
Posts1,055,814
#150400 01/21/2007 5:28 AM
Looking to convert my 70 C50 to power steering. Any one know what boxes fit other than the 67-72 medium duty trucks? does the steering box only fit the medium dutys? not too many yards here that have any older stuff around especially meduim dutys. Thanks
1970 C50 dump! saving orphans from the CRUSHER
#150401 01/26/2007 3:48 AM
Is the power steering in the box like a regular truck? or is there a external ram that adds assist? someone said that it's not in the box, these trucks had a external ram that added assist?? looks like a large steering damper connected to a power steering pump. does this sound correct? If so does any one where I can get this set up?
#150402 01/26/2007 4:45 AM
I've got a regular pick-up steering box on my 48 1 1/2 ton. I think it came from a '78 Chevy 4X4 3/4 ton. I don't have any problems at all, and I even run an 8' plow on it,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#150403 01/27/2007 5:32 AM
Did you have to do any modifications? pitman arm/drag link must be different?
#150404 01/27/2007 3:31 PM
Oh yeah, but that was on a 48. I'm not sure how your C50 box is set up. I'm just stating that my steering box is heavy enough for my big truck. I'm not sure if you'll need a standard pick-up box or a 4X4 box for your truck,
Good luck,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#150405 01/27/2007 8:00 PM
Yes the power steering for your truck is a power assist ram. However the control valve is in the box so you will need the box ram hoses pump and linkage for the ram attachment. This system works much better than most power assist setups. Because the valve that controls the ram gets its input from you at the boxes input shat instead of from the box at the draglink. This gives much better road feel much like a standard power box. This box will look like a normal Saginaw box but the output shaft is horizontal like your stock manual box instead of vertical and it has four ports instead of two. An input a return a left turn and a right turn port.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#150406 01/28/2007 1:00 AM
Thanks, The problem is finding these parts. these trucks are few and far between around here. Any one got any trucks they are parting out?
#150407 01/28/2007 4:19 AM
I have a box from a 78 GMC 6500 that may work. I was considering using it on my 48 in place of my IH Scout box, but with my diesel and other goodies it would not fit.
It may fit your truck nicely? Can you post a picture of the original setup?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#150408 01/29/2007 3:14 AM
I'll try to get a picture of the set up
