7 members (Uncles51, 78buckshot, Peggy M, Youngin' Tut 59, Cletus1950, delwrench, 1 invisible), 105 guests, and 2 robots.
Topics128,174
Posts1,057,048
Members48,458
#149519 12/17/2006 9:29 PM
Big Bolt Forum Co-moderator
My '48 two ton does not have a hoist. Would it be difficult to ad a hoist? What do they consist of, a pto off the tranny and a hydraulic pump and cylinder/cylinders? Keep in mind I am a real newbie, as newbie as it comes. I just love old trucks and I couldn't resist. By the way my truck has already given me a lot of enjoyment. Even though I found out it has no wipers!!!! The story on that one: the pervious owner told me to merely hook up the line that was coming out of the firewall. Turned out to be the drain hose for the cowl vent. Too funny to worry about. I have a line on a wiper motor and linkage already. The previous owner said somewhere down the road it was covereted to an electric wiper over the driver's window. You can see where it was installed and there is a motor on the firewall that I am guessing doesn't do anything now.
1948 Chevy 2-Ton
#149520 12/18/2006 12:18 AM
53moneypit is the expert on hoists. I'm sure he'll be along soon. He will be able to tell you everything you'll need to know.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I've been 900 miles from home all last week so maybe I was an expert then where no one knew me,HA. Well I'm back home now so I'd better be right now, huh?
It isn't difficult adding a hoist but it does matter how your body is built. If it has wooden longsills (the stringers on top of the frame running front to rear)then it is not a job for a self described newbie. Let a pro handle that one. So let us assume that your body has steel longsills. Generally speaking you'll need 6" sills and 3-4" crossmembers to have room to mount a hoist. For arguments sake we will also assume that you have chosen a scissor design hoist. Twin cylinder hoists are more period correct for a 40's-50's truck but they are increasingly difficult to find new and used one's are generally not worth trusting your life to. So a scissor type it is. Next choose the model for the body length you have. Most manufacturers will have a couple of models for your length, a standard and a heavier capacity unit. The standard models are the best bet as a rule. The "bigger is better" rule is a waste of money 90% of the time. Next decide if you want a PTO driven pump or a 12V DC driven pump. PTO's for the old trannys are not made anymore so if you go that route you'll have to come up with a used PTO and even parts for them are like hens teeth.
I'd go(did)with the electic pump/valve unit. There are several manufacturers of hoists in the US to choose from but far fewer in BC.
Next choose a frameless type or a subframe style hoist. The subframe style is much easier to install as the both the hinge and the scissor frame are already attached to the subframe. Then cut the rear of the frame to the desired length and install the subframe or the hinge per the directions of the manufacturer. The hoist frame is then installed if the frameless style is chosen and everything bolted down and welded per instructions. Next the pump/valve ***'y is is installed, wired to the battery and the control cable or wired switch is connected. Then the body is reinstalled and the hoist welded to the longsills per instructions as well as the hinge assembly and your pretty well complete except for the taillamps and body lights.
There are a LOT of other things that can go wrong with what I have descibed but it is impossible to tell what they may be without seeing your particular truck. I recommend that you take it to someone who does a lot of this type of work and get thier thoughts before attempting this job. There is nothing like experience so try to find someone who has been around a long time and knows these old trucks and the problems encountered with them.
If you go ahead with this project feel free to contact me directly with all the info and pictures of your rig and I'll help steer you through it all.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Wow... thanks for all of the info. To me it sounds like a semi-big job to add a hoist. I will look at some rigs that are around. I go to the Shelton,WA show most years and have seen some nice rigs. I will take lots of photos. Here is a site with some pics of my truck.
http://photoshare.shaw.ca/gallery/pstanley/
1948 Chevy 2-Ton
Just a note about the 2 ram hoists..If you do go that route, the 1 thing you have to always remember:
When raising the bed/box you have to be on flat ground or you'll tip it over..The 2 ram hoists don't have the sideways play that a single ram has...
And here's a source for a hoist kit:
surpluscenter.com
Good prices, and good to do business with
Geoff
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
Junior Member
Junior Member
A company called Crysteel makes some very nice subframe type units that are virtually fully self contained. Moneypit is right. All of my trucks have had a PTO driven pump, but if I had to set one up, I would definantly go with an electric subframe or "lay in" unit as well.
Snapoff brand tools
1948 Chevy 6400
1949 Chevy 4400 (parts truck)
"The 2 ram hoists don't have the sideways play that a single ram has..."
Sorry to inform you differently old Stick but you are Oh So Wrong. Two cylinders by the very nature of doubling every moving part of the mount make them have more movement. Add to that the fact that one is always trying to lift more than the other since they cannot be truly equalized and you increase the twist on the body. This is why scissor frames were designed in the first place. They are stabilizers in and of themselves.
Rezman..I was one of the early on Crysteel dealers and later worked as a sales rep for them. Not really any better nowdays than two or three others on the market. They have all become a commodity.
Dave
:rolleyes: frown
Stuart
