5 members (Bill Hanlon, carbking, HandyAndy, dt235sd, Otto Skorzeny), 91 guests, and 3 robots.
Topics128,053
Posts1,055,777
#1490302 03/02/2023 3:58 PM
Cleaning out store room, thinking about moving some engines. Need a ballpark value...anyone.
1946 1/2-Ton Chevy
I just gave $300.00 for a running condition late model 261 with the big oil gallery ports and a full flow filter setup, canister, lines, and all
It also included a numbers-correct Rochester B carburetor, clutch, pressure plate, flywheel, bell housing, generator, and starter. It was driven into the shop a few weeks ago before they pulled the engine and tried to make the cylinder head fit a 292. Somebody else's stupid attack was my good fortune. A head gasket and a little work would put it back into running shape. I'm also in the process of acquiring a basket case 261 with a repairable cracked block for $150.00 plus shipping. People who are asking outrageous prices for "rebuildable" stovebolt engines are usually engaging in wishful thinking.
I would weight the value of a 261 block, crank, & caps without damage, cracks, large overbore, seizure, stripped threads, etc. as $500. delivered (adds 10.8% to engine size), by comparison with stroking with an offset crank journal and 292 rods (adds 4.8% to engine size) at far greater cost.
That $500. figure is a small percentage of the total cost of a high performance build, and an excellent value for the money.
I've been GIVEN several 216's and 235's, and a couple of 261's just to haul them away. I've got two more 235's and two GMC 270's to pick up, free for the hauling, once I get around to making some road trips. Once I achieve room temperature, I expect that my family will be able to give me a first class funeral just by selling several truckloads of scrap iron!
1 Offline
A year ago I was offered a complete 261 less bellhousing and flywheel for $350. Should have taken it.
1951 3800 1-ton
In the DITY Gallery
They're not making any more 261s, or 270s either.
Crusing in the Passing Lane
I still have a military 302, no one seems interested!
Ed
