| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Cleaning out store room, thinking about moving some engines. Need a ballpark value...anyone. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | I just gave $300.00 for a running condition late model 261 with the big oil gallery ports and a full flow filter setup, canister, lines, and all It also included a numbers-correct Rochester B carburetor, clutch, pressure plate, flywheel, bell housing, generator, and starter. It was driven into the shop a few weeks ago before they pulled the engine and tried to make the cylinder head fit a 292. Somebody else's stupid attack was my good fortune. A head gasket and a little work would put it back into running shape. I'm also in the process of acquiring a basket case 261 with a repairable cracked block for $150.00 plus shipping. People who are asking outrageous prices for "rebuildable" stovebolt engines are usually engaging in wishful thinking. Jerry
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | I would weight the value of a 261 block, crank, & caps without damage, cracks, large overbore, seizure, stripped threads, etc. as $500. delivered (adds 10.8% to engine size), by comparison with stroking with an offset crank journal and 292 rods (adds 4.8% to engine size) at far greater cost. That $500. figure is a small percentage of the total cost of a high performance build, and an excellent value for the money. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | I've been GIVEN several 216's and 235's, and a couple of 261's just to haul them away. I've got two more 235's and two GMC 270's to pick up, free for the hauling, once I get around to making some road trips. Once I achieve room temperature, I expect that my family will be able to give me a first class funeral just by selling several truckloads of scrap iron! Jerry
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | A year ago I was offered a complete 261 less bellhousing and flywheel for $350. Should have taken it. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | They're not making any more 261s, or 270s either. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I still have a military 302, no one seems interested!
Ed
