| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Hello fellow Big Bolters...
Not sure if this is the right place for this question...but here goes:
Does anyone know where I can buy sheets of cork and also the heavy black "paper-like" material that they use for common gaskets (i.e. not exposed to direct heat like on an exhaust manifold)?
I have a feeling that finding some gaskets for my restoration may be difficult so I may have to make my own (after I make a paper template)...but I don't know where to buy the gasket sheet stock?
Any resources would be appreciated!!! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Any good parts store should have sheet gasket material. Try the farm stores, too.
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | I used to work at a napy an they had it. I believe you can still get them there. | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | It can be bought at any parts house in a roll. You can get thin,meduim, or thick. Also can get asbestos for exhaust flange applications.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | You might have to pester the younger computer jockeys... they might not know what you are talking about.
-W | | |
