Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (TrknGMC), 31 guests, and 1 robot.
Topics128,010
Posts1,055,299
Members48,419
#148465 09/26/2006 1:32 PM
I'm curious as to what engine sizes were offered in a 1953 Chevy 4400. I've searched the forums and can't seem to find a previous post that answers my question. I know there's a site you can look it up by casting number, but I can't get my hands on that number right away. Also, who is a good source for internal parts for the older sixes? Thanks for the help.
1949 Studebaker 2R16A
1961 Chevrolet Impala
1968 Chevrolet Corvette Roadster
1971 C10
#148466 09/26/2006 3:55 PM
A 1953 Chevrolet 4100, or 4400 series 1 1/2 ton truck, would have came standard with a 216ci. Thriftmaster 6 cyl. engine. A 235ci. Loadmaster 6 cyl. was optional. 1953 Chevrolet 6100, 6400, & 6500 series 2 ton trucks, came standard with the 235ci. Loadmaster.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#148467 09/26/2006 4:46 PM
Thank you very much.
1971 C10
#148468 09/27/2006 3:49 AM
While we are on the subject, What engine would have come in a 56 4400? I know mine originally had a 6 cyl, but it was swapped out for a small block some time in its history. Any Idea where to locate an original six? Or maybe i should just keep the v8. I dont know. If i go all original with the resto i will want an original six.
Chris
1956 Chevrolet 4400
1959 Chevrolet Viking 60
1968 Chevrolet el Camino
2002 Chevrolet 1500HD 4x4
#148469 09/27/2006 4:32 AM
1956 I would think the big truck had a V8-265. There was a thread somewhere about what year and availability of the V8. That would answer some questions! try the engine driveline forum back a little ways.
#148470 09/27/2006 6:01 AM
the "base" engine for 56 was the usual 235 I6 that lasted til 62, the optional V8 in a 56 would have been the 265 - the way to tell if it's likely an 'original' V8 is if it uses the front mounting pegs [original] or the side mount pads [adapted]
#148471 09/27/2006 12:17 PM
Also, the easiest way to distinguish between a 265 and any other small block chevy is the valve covers, providing the heads are 265 heads. The bolts that hold the valve covers on are staggered on a 265, not symetrical like any other small block.
1971 C10
#148472 09/27/2006 3:16 PM
thanks for the info guys
Chris
1956 Chevrolet 4400
#148473 09/27/2006 9:14 PM
H.I.,
I beg to differ. Staggered bolts on valve cover came till 59, also on 283. One other trick is the lack of side bolts bosses on the 265 only. There were 283 made in 57 that also lacked the side mounts. If it has side mounts it is not a 265, but if it lacks, can be a 265 or a rare 57 283.
Alexandre Garcia
#148474 01/05/2007 3:16 AM
Another check for a V8 original in a TF truck is whether the front engine mount frame brackets are rivited or bolted.
