| | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 37 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 37 | I'm curious as to what engine sizes were offered in a 1953 Chevy 4400. I've searched the forums and can't seem to find a previous post that answers my question. I know there's a site you can look it up by casting number, but I can't get my hands on that number right away. Also, who is a good source for internal parts for the older sixes? Thanks for the help.
1949 Studebaker 2R16A 1961 Chevrolet Impala 1968 Chevrolet Corvette Roadster 1971 C10 | | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | A 1953 Chevrolet 4100, or 4400 series 1 1/2 ton truck, would have came standard with a 216ci. Thriftmaster 6 cyl. engine. A 235ci. Loadmaster 6 cyl. was optional. 1953 Chevrolet 6100, 6400, & 6500 series 2 ton trucks, came standard with the 235ci. Loadmaster. | | | | | Joined: Jun 2005 Posts: 37 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 37 |
1949 Studebaker 2R16A 1961 Chevrolet Impala 1968 Chevrolet Corvette Roadster 1971 C10 | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | While we are on the subject, What engine would have come in a 56 4400? I know mine originally had a 6 cyl, but it was swapped out for a small block some time in its history. Any Idea where to locate an original six? Or maybe i should just keep the v8. I dont know. If i go all original with the resto i will want an original six.
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 1956 I would think the big truck had a V8-265. There was a thread somewhere about what year and availability of the V8. That would answer some questions! try the engine driveline forum back a little ways. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the "base" engine for 56 was the usual 235 I6 that lasted til 62, the optional V8 in a 56 would have been the 265 - the way to tell if it's likely an 'original' V8 is if it uses the front mounting pegs [original] or the side mount pads [adapted]
Bill | | | | | Joined: Jun 2005 Posts: 37 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 37 | Also, the easiest way to distinguish between a 265 and any other small block chevy is the valve covers, providing the heads are 265 heads. The bolts that hold the valve covers on are staggered on a 265, not symetrical like any other small block.
Chris
| | | | | Joined: Dec 2001 Posts: 146 Member | | Member Joined: Dec 2001 Posts: 146 | H.I.,
I beg to differ. Staggered bolts on valve cover came till 59, also on 283. One other trick is the lack of side bolts bosses on the 265 only. There were 283 made in 57 that also lacked the side mounts. If it has side mounts it is not a 265, but if it lacks, can be a 265 or a rare 57 283.
Alexandre Garcia
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Another check for a V8 original in a TF truck is whether the front engine mount frame brackets are rivited or bolted. | | |
