| | | Forums66 Topics128,028 Posts1,055,413 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Just wondering if the top bars of the grill on an art deco cabover are the same as far as top to bottom, and whether or not theres any differences between chevy and gmc?
These are the 4 bars above the main grill. They look similar in pics but we all know how that goes...
Any ideas? Thanks, Jeff | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hi Jeff,
Congrats....where is it coming from? Do tell do tell...more info
Not so lucky regarding the lengths.
They get sequecially smaller (shorter), bottom being the shortest. Top is somewhere around 26", second is about 25.5 and the lower one is 25.25 or so. Old messed up tape I just used, but that will be close. I am going to have some extra in a couple of mos. if you haven't found any or don't have yours. They won't be cheap, but let's see what they look like. Tom | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Thanks Tom, Ill wait for the rest of the info and pics as the guys bringing it up from Kansas for me and I wont be thrilled until its sitting in my driveway!
It would be here tommorow but he found a 90 year old Henderson motorcycle with its old inline 4 and hes digging through junk piles finding the rest of its parts. I understand completly Id be digging through the junk pile to!
Its a 47 gmc and is missing the bottom 3 bars. Let me know about those extras Tom, Thanks.
Anyone know if gmc and chevs are the same?
Jeff | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | I believe GMC and Chevy are the same regarding the hood, but the lower grill section runs horizontal instead of vertical on GMCs. Only one slight problem that I can forsee and that is the bottom bar on mine reads "chevrolet".  So I will probably be capable of helping you find the top two you are missing, but you are going to have a tough hunt for the the GMC bottom piece. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | I have a 1945 GMC COE. My top grill bars all measure about 25 7/8 inches. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Check your hood to see if all of the openings are the same width (when it arrives). I will check mine...dark now. I have to think Chev and GMC have the same hood. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | The grill openings in my GMC hood get progressively smaller as they go down just like the Chevy. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Well, that sure is interesting...I am no expert, but I am going to guess since the difference is so little that they could go either way from the factory. I do know that mine are slightly different lengths (smaller as they get lower) on more than one vehicle. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Rustednuts, I sent you a PM with a picture of my COE. Tomcoe, I sent you a PM with a picture of the GMC grill. | | | | | Joined: Mar 2001 Posts: 21 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 21 | Rusty46,I like to see a picture of your 45 GMC,because my husband has a 1945 GMC COE Victory truck,model number AFR522,it has a 308,airwipers,air brakes,air spiltrearend. and here is a picture. http://www.stovebolt.com/gallery/oeleis.htm
Times are changing-By Bob Dylan Cindy in Oregon 1945 GMC COE Victory Truck 5ton COE- NOT FOR SALE 1955 Chevy First series 5 window p/u
1947 Antique Husband only series
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Hi sleeper55. I sent a picture to Oly. Your link identifies your COE as a 5 ton model FB ? If your COE is a AFR522, it is a 3 ton tractor with a wheelbase of 136 inches. They were made in 1940,41,45,46 and 47 according to the information I have. Total production was 1538 vehicles. A 1945 AFR522 would have a serial number between 421-1120. I looked at a GMC AF model today. No ID tag on it but it had a 24000 gross weight sticker on the door. The gauges were the same as a 39 GMC, except mounted in the center of the dash, otherwise all big truck, like yours. First one I've seen in person. He has a cab and front sheetmetal for sale if you're interested. | | | | | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Thanks for the pic Rusty46. I've been kinda busy lately. Yes, I would be interested in the cab and sheetmetal. Also possibly the engine if he has it. The wheel base was extended at the factory by 24 inches on my truck. It's setup to either be a tractor or a flatbed with beavertail. The reason I was saying it was a 5 ton is that was what the scale master told me when I crossed the scales at 46,000 lbs gross. He told me it was a five ton only rated for 28,000 lbs gross but since I had farm tags there really wasn't any weight limit other then what my tires could hold. He figured the tires would give up before the truck would. I would enjoy getting a fifth-wheel and trailer (of era) with air brakes for it. Once again thanks for the picture.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Hi Oly, I sent you a PM. The model AFR-523 had a wheelbase of 160 inches which was 24 inches longer than the 522. There was also a model 524 and 525 as well as a 521, all with the 308 engine but different wheelbases. | | | | | Joined: Mar 2001 Posts: 21 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 21 | Rusty46 the title and the plate inside of the truck says AFR522 and plus from what Donald Meyer(GMC Truck Historian)Oly's 1945 GMC COE was called Victory models.If you like to have his address to check yours out let me know.
