6 members (BarryP, Wayne67vert, Otto Skorzeny, steves66, Shade Baby, 1 invisible), 145 guests, and 3 robots.
Topics128,140
Posts1,056,774
Members48,454
#147827 08/07/2006 1:52 AM
Click below and go to the Detroit folder.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
#147828 08/07/2006 2:04 AM
Neat Grigg! Nothing sounds cooler than those air spinners. You'll get great looks at the drivethru!
Jim
Good luck with your project!
#147829 08/07/2006 3:23 AM
Amazing amount of work you've put into this truck. I'm seeing the front engine mount as a rubber block but those rear bearing blocks look pretty darn solid to me. Is that what I see or are my eyes playing tricks on me?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#147830 08/07/2006 3:31 AM
The front mount and the section of crossmember are stock for the 78 GMC 6500 the engine came from. It is actually just like the stock 216 mount just a tad bigger.
The rear mounts started as rear mounts for a Louisville Ford truck. Like would have come with a 3208 Cat, and even the gas v8 engines too.
I bought new rubber parts and made the engine side. I machined the frame side from what was originaly the engine side of the ford setup.
The rear mounts hang all of the engine and trans less about 125# on the front mount.
Not to confusing is it?
Grigg
---All pictures---
#147831 08/07/2006 8:00 AM
Simply amazing. Did you completely design that disc emergency brake???
#147832 08/07/2006 9:43 AM
yes, I bought the caliper, reused the lever, and made the rest.
---All pictures---
#147833 08/08/2006 6:54 AM
Where did the caliper come from????
#147834 08/09/2006 2:12 AM
From Mico.
http://www.mico.com/products/displaysubinfo.php?id=25
If you need the part number I can get it, I forget price, but a good bit over 100.
---All pictures---
#147835 08/09/2006 3:27 AM
That is going to be one neat ride. You will have to make us a video of it so we can hear it.
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
#147836 08/10/2006 1:14 AM
engine looks better than new
#147837 08/10/2006 10:16 PM
Hi Grigg! Boy it looks good! It looks like it was an original installation. What Detroit engine is it? The last picture is of the frame you found for me right?!! Looks great!
Rick
#147838 08/13/2006 3:07 AM
I am trying to build it as GM would have built it in 48 if the 4-53T engine was available then.
The frame is almost ready for sand blasting and powder coating. I have finished making pieces for it and also have finished putting in all the missing or broken rivets. Only some welding and stuff to do to the front crossmember now.
Grigg
---All pictures---
