2 members (Ponchogl, Shardean),
56
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | My 47 GMC 283EC needs axle seals. The numbers are 220233 for the inner and 2200944 for the outer. They are felt type seals and I cannot cross the numbers with anyone here. I need help. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | notaclue- ask your parts house what is the last year they go BACK to. Then see if it is available. I checked with Advance Auto and got mine for a 37 chev. over night. Take your old ones with you and if the last year they list is say a "52" then ask them to look at the picture. Advance had a picture of mine and also the measurements so take a dial indicator with you or use yours. They ran the rear seals/bearings for several years. Not sure about the big trucks but at least the smaller ones....big ones should be the same. | | | | | Joined: Jul 2006 Posts: 149 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 149 | I'll take a look at my books and see what I can find for numbers for you.... and also what years they were used up to.... Michael \'48 chev 2-ton boom truck (Boomer) '49 Chev 2-ton flat bed '65 Chev 35ft school bus '88 GMC 6500 '72 Superior 26ft class "A" coach '50 Farmall "M" '71 MGB GT '68 Austin-Healey Sprite '65 Austin-Healey Sprite and various other odd British cars and lots of old radios..... Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I just got new seals for the front of my 1/2 ton and was told they dont make felt seals anymore, just rubber and steel.
Try calling or going into a bearing place they are way more helpful then you might think and helped me out immensely.
Graf nice to see another WA resident on the bolt!
Jeff | | |
