5 members (68ironhead, Phak1, 49nut, Gray_Ghost, 1 invisible), 64 guests, and 1 robot.
Topics128,049
Posts1,055,691
#1461 04/07/2005 10:24 PM
New Stovebolter, although this is the second time around for me. Had a 59 stepside and sold it some years ago, and have regretted it ever since. frown
Just purchased a beautiful original 58 stepside, and am contemplating changing rear end ratios as I go through the mechanicals. Has the stock 235 and three on the tree, and I see in some catalogs a 3:36 ring and pinion set. Would this be a mistake behind the 235 or do I leave the 3:90 in?
All input gratefully accepted! smile
Richard
58 3104
#1462 04/07/2005 10:32 PM
Riding in the Passing Lane
I put a 3:38 in a 56 I had & it worked great. It made it very road worthy. The parts are pretty expensive though but I would rather keep it original than changing to a later rear end & modifying everything.
1972 Chevy c10 Cheyenne Super
#1463 04/08/2005 1:06 AM
Wrenchbender Ret.:
I see you live in Lenexa, KS. Did you do the rearend ring & pinion changeout? I have purchased a master setup kit, including 3.08 ring & pinion and Eaton posi unit that I plan to have installed in my '66, C-10 that has a factory 327cid/SM420 granny-low 4-speed and factory 3.73 posi. Any suggestions on a dependable, local mechanic that has the tools and know-how to do the swap? Thanks in advance for your input.
#1464 04/08/2005 9:14 PM
Tony
There is a guy I know in Olathe. I have his shop name at work, but here's where to find him. Garrett is his first name, he goes by Piston. Easiest to contact him through www.heartlandrc.com
Fred
52 3600
69 C-10
#1465 04/08/2005 9:30 PM
richard, go to www.randy\'sringandpinion.com then to calculator on that page.i have 54/3100/235 with 2/1 barrel carbs and fenton headers with 2.73 gears. it is fine on the highway but in town lugs. i have 235/70/15 tires on the rear. you can figure your tire height at, www.1010tires.com hope this helps.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#1466 04/09/2005 5:46 AM
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
#1467 04/09/2005 5:55 AM
Apprentice
Apprentice
If you have trouble finding Randy's, remove the apostrophe. Thanks for the link info.
When I find out what I'm doing, I'll let you know if I'm in too deep.
#1468 04/10/2005 4:07 AM
Thanks, everyone. Appreciate the information. Called Randy's and they seem to not have supply of the 3.38. Will keep looking, as I want to keep the truck as original as possible.
Richard
Richard
58 3104
#1469 04/10/2005 4:50 AM
Richard - look around at good specialty rear end repair places - there's a place up here in Van BC called Rear Ends Only that has 338 gears for the TF rear in stock, as well as the original 390's - talked to'em a while back, and the prices for the 338 are the same as the 390! I'd bet there's someplace in FL similar
the other possibility is to find an original overdrive trans for the TF, which will give ya the highway speed at lower rpms, but still give the low speed pull these trucks do so well
#1470 04/10/2005 3:23 PM
Hey li,l red.
I don,t know any place to get it done. I did mine myself but i,ve never worked on a posi. Do you ever go to the cruise night on friday,s in Olathe. I usually go when the weather is good.
George
#1471 04/10/2005 6:18 PM
Fred T thanks for the headsup on Piston. I will attempt to contact him. I would like to get my '66 C-10 buttoned up this spring. Wrenchbender Ret. I have not been to the Olathe Cruise Night. E-mail the info and I'll try to make it to the next one.
Thanks for the input fellas.
#1472 04/10/2005 10:03 PM
The cruise night is every Friday evening at the Sonic drive in on Sante Fe drive about 1 mile west of I-35. I,m a bald headed old man & I,ll be in a 70 white Chev. step side pickup or black Skylark convertible. smile
