7 members (Hotrod Lincoln, Oldcaliforniakid, 49nut, frogfarmer, Stovebolt48, mason86, Woodcmiami),
89
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#1461 04/07/2005 10:24 PM | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | New Stovebolter, although this is the second time around for me. Had a 59 stepside and sold it some years ago, and have regretted it ever since. Just purchased a beautiful original 58 stepside, and am contemplating changing rear end ratios as I go through the mechanicals. Has the stock 235 and three on the tree, and I see in some catalogs a 3:36 ring and pinion set. Would this be a mistake behind the 235 or do I leave the 3:90 in? All input gratefully accepted!
Richard 58 3104
#1462 04/07/2005 10:32 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I put a 3:38 in a 56 I had & it worked great. It made it very road worthy. The parts are pretty expensive though but I would rather keep it original than changing to a later rear end & modifying everything. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Wrenchbender Ret.:
I see you live in Lenexa, KS. Did you do the rearend ring & pinion changeout? I have purchased a master setup kit, including 3.08 ring & pinion and Eaton posi unit that I plan to have installed in my '66, C-10 that has a factory 327cid/SM420 granny-low 4-speed and factory 3.73 posi. Any suggestions on a dependable, local mechanic that has the tools and know-how to do the swap? Thanks in advance for your input. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Tony There is a guy I know in Olathe. I have his shop name at work, but here's where to find him. Garrett is his first name, he goes by Piston. Easiest to contact him through www.heartlandrc.com
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | richard, go to www.randy\'sringandpinion.com then to calculator on that page.i have 54/3100/235 with 2/1 barrel carbs and fenton headers with 2.73 gears. it is fine on the highway but in town lugs. i have 235/70/15 tires on the rear. you can figure your tire height at, www.1010tires.com hope this helps.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jul 2000 Posts: 2,189 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,189 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jul 2003 Posts: 15 Apprentice | | Apprentice Joined: Jul 2003 Posts: 15 | If you have trouble finding Randy's, remove the apostrophe. Thanks for the link info.
When I find out what I'm doing, I'll let you know if I'm in too deep.
| | | | | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | Thanks, everyone. Appreciate the information. Called Randy's and they seem to not have supply of the 3.38. Will keep looking, as I want to keep the truck as original as possible.
Richard
Richard 58 3104
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Richard - look around at good specialty rear end repair places - there's a place up here in Van BC called Rear Ends Only that has 338 gears for the TF rear in stock, as well as the original 390's - talked to'em a while back, and the prices for the 338 are the same as the 390! I'd bet there's someplace in FL similar the other possibility is to find an original overdrive trans for the TF, which will give ya the highway speed at lower rpms, but still give the low speed pull these trucks do so well
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Hey li,l red. I don,t know any place to get it done. I did mine myself but i,ve never worked on a posi. Do you ever go to the cruise night on friday,s in Olathe. I usually go when the weather is good. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Fred T thanks for the headsup on Piston. I will attempt to contact him. I would like to get my '66 C-10 buttoned up this spring. Wrenchbender Ret. I have not been to the Olathe Cruise Night. E-mail the info and I'll try to make it to the next one.
Thanks for the input fellas. | | |
#1472 04/10/2005 10:03 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The cruise night is every Friday evening at the Sonic drive in on Sante Fe drive about 1 mile west of I-35. I,m a bald headed old man & I,ll be in a 70 white Chev. step side pickup or black Skylark convertible.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
