3 members (78buckshot, Ridgeback, 1 invisible), 109 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#1462550 08/13/2022 10:20 PM
On a 60-66 the door lock should have a bit of detent when you lock/unlock by pushing handle forward right? The driver's door lock seems to work, but doesn't really click into place. The passenger's door is a lot better.
Also, is there an easy way to make it so you can lock driver's door and then close it?
I know you can get tumblers for everything matching key, but I want to do something in the mean time.
1961 Chevy C40 Flatbed 261
High Plains #1467898 09/23/2022 5:46 PM
Socket Breaker
Socket Breaker
Driver side gets used more, have you tried lubricating it?
It may be worn out. grin
High Plains #1467904 09/23/2022 6:11 PM
Good suggestion Woogeroo it works by friction and they do wear. Or it could need adjustment for the reason I mentioned.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
High Plains #1467912 09/23/2022 7:13 PM
I dont have a door key. So what i do when i want to lock up the truck it is lock pass door from inside. Roll up drivers door glass, leave vent window open. Shut door. Reach in through vent to lock door, then close vent. Most people wont notice the vent window unlocked. And if they do, wont know how to unlock door anyhow. Ive been meaning to get a door key setup, about 2 years ago. headscratch
