8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln),
78
Mod | | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2022 Posts: 117 'Bolter | | 'Bolter Joined: Mar 2022 Posts: 117 | On a 60-66 the door lock should have a bit of detent when you lock/unlock by pushing handle forward right? The driver's door lock seems to work, but doesn't really click into place. The passenger's door is a lot better. Also, is there an easy way to make it so you can lock driver's door and then close it? I know you can get tumblers for everything matching key, but I want to do something in the mean time.
1961 Chevy C40 Flatbed 261
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Driver side gets used more, have you tried lubricating it? It may be worn out.  | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Good suggestion Woogeroo it works by friction and they do wear. Or it could need adjustment for the reason I mentioned.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | I dont have a door key. So what i do when i want to lock up the truck it is lock pass door from inside. Roll up drivers door glass, leave vent window open. Shut door. Reach in through vent to lock door, then close vent. Most people wont notice the vent window unlocked. And if they do, wont know how to unlock door anyhow. Ive been meaning to get a door key setup, about 2 years ago.  | | |
