1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 13 New Guy | | New Guy Joined: Apr 2006 Posts: 13 | I picked it up for 275.00 72 c60. 16 foot flat bed, 366 big block, 5 speed, 2sp rear, pto winch, and hydraulic lift gate. It doesn't run, and I need to bring it home. I'm thinking of using my 39,000 lb rated military towbar hooked to the front bumper, by drilling 2 one inch holes and running the pins through. Any ideas? Pics are here: http://pg.photos.yahoo.com/ph/gimpyrobb/album?.dir=/5a2fre2&.src=ph
why me?!
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Looks like a great find!
Your tow bar is probably stout enough. Provided your attachement is good, the remaining question is what are you towing it with?
My primary concern is does your tow vehicle have adequate brakes to top it?
If you are planning to tow with a 1/2-ton pickup you could easily get into trouble. If you have a dually pickup rated to pull 10,000 plus it still may be marginal when it comes to brakes.
I don't know the rules in Ohio. In some states the law says if the load weighs more than some fraction of the tow vehicle brakes are required on the load.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2006 Posts: 13 New Guy | | New Guy Joined: Apr 2006 Posts: 13 | Yeah, thats what I'm worried about. I told my buddy that it weighs 11,300lbs and he said he's towed more behind his f250 powerchoke. I'm thinking I may rent a uhaul to bring it back with. Anyone else do that?
why me?!
| | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | gimpyrobb, A better idea, if possible, would be to remove the bumber and bolt the tow bar directly to the bumper mounting brackets on the frame. Here is how I connected mine on my 1964 Chevy C60. I just use the tow bar to move my truck around the yard as opposed to over the road. However, I'd be a bit concerned if it were mounted to the bumper... Just offering my 2 cents worth. Best of luck getting your big rig home...and keep us posted on your progress  | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My 454 powered K3500 weighs about 5700, so maybe a Powerstroke F250 is in the same neighborhood? But it all comes down to how big are the brakes...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2006 Posts: 13 New Guy | | New Guy Joined: Apr 2006 Posts: 13 | I guess its hard to see, there is quite a large plate(no less than 1/2 inch steel) bolted on the front. The bolts(4 or 6 of them) go through the frame. I am confidant that this will be of adiquate(sp?) strength. I just want to be sure the tow vehicle will stop the beast.( You don't have to go, but you HAVE to stop!)
why me?!
| | | | | Joined: Apr 2006 Posts: 13 New Guy | | New Guy Joined: Apr 2006 Posts: 13 | Also, One of my old bosses has a 28ft box truck, I'll prolly call him up and ask the "favor". Its good to be resourceful!
why me?!
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | As I've said before on this forum,I have towed a C-60 with a half ton,including a fairly steep summit,but I really don't recommend it. I only did because I had no other option at the time. My pick up had no problem pulling it,though lane changes were a little tense.It even stopped reasonably well,if only because I was looking WAAAAAaaaayyyy ahead of the truck,preparing for every move far before its time was at hand. I began slowing for turns and stops a mile before I reached them. If I'd been cut off or someone had pulled out in fromt of me,it could've been ugly. If your boss will work something out with you,go with that. Speed | | |
