Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Wayne67vert, 78buckshot, 1 invisible), 78 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1460976 08/01/2022 4:07 AM
' Offline
Speedometer on '37 1/2 ton doesn't register at all until I hit 30 mph then it seems to work fine
after that. Where do I start with this one?
You may need to take the cable off and spray cleaner the full length.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
You can unscrew it at the gauge and pull the cable out of the sleeve. You don't necessarily have to remove the entire cable from the truck.
DO NOT be tempted to use graphite as a lubricant.
1950 Chevrolet 3100 (Ol' Roy)
'37 barn find #1461084 08/01/2022 11:11 PM
See my previous post on the second page titled SPEEDO NEEDLE BOUNCE
1946 Chevy 1/2-Ton
'37 barn find #1461092 08/01/2022 11:33 PM
' Offline
So I pulled the sleeve and cable, removed the cable and sprayed brake cleaner through the sleeve until it came out clear. Put some white lithium grease on the cable and now it works perfectly
That's awesome!
37barnfind See if your dial hand is warped and rubbing on the glass,you may see a bow in it,maybe even a track on the glass. Mine does it too,hate to disturb it cause 2-speed axle changeover is working and it's accurate . Is 71 years young miles work too,most stuff on the truck works 118,000 so far.
