3 members (IHPWR, David Bush, Gdads51), 130 guests, and 3 robots.
Topics128,142
Posts1,056,472
Members48,441
#1460488 07/28/2022 2:27 PM
Glad to be a newbie on this forum to learn a lot about the 1953 I just purchased three weeks ago.
So far I know it has a 235 ci six-cyl out of a 1954 passenger car, converted to 12v, not sure when painted, Coker bias-plys, 3 on the tree, nice interior, no radio, guessing 4.11 rear. Had a lube job, drained trans & rear.
Added new fluids. Replacing VC gasket/ Old one fell apart in a dozen pieces, hence oil leaking. Does not smoke. Will drain coolant system & replace thermostat. Ordered an Assembly manual. Have a 48-53 truck shop manual. Will replace plugs & wires. Had generator rebuilt.
The truck has a little rust in the floor pan, but not a priority right now. It starts and runs fine, but leaks some oil. Does not appear to burn any. No smoking. Just changed the oil & air filter. Air filter is an aftermarket and not the oil bath. I have tinkered with cars for 60 years. Currently have a 31 Ford Model-A and a 64 Corvette.
1953 Chevy 3100
I have recreated my Dad's old work truck with a 5 window.
Welcome to the Bolt. Sounds lie a really nice project and you can find all the help you need right here. Take the time to sit down and check out the forums and tech tips among other things. See you around the garage.
Welcome to the Stovebolt madness. There is no cure! shake
Welcome to the 'bolt. And please share some pictures of your project.
Another quality post.
Real Trucks Rattle
Redbird #1460740 07/30/2022 12:56 PM
AD Addict & Tinkerer
Welcome to the ‘bolt! Please post some pictures as well. There are step by step instructions on how to post images on the left margin on this page. We’ll see you around the garage!
Phil
Project Journals
Stovebolt Gallery Forum
Here are some pictures.
1953 Chevy 3100
Crusty Old Sarge
Crusty Old Sarge
That is one sweet looking truck. welcome to the "BOLT".
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
thumbs_up
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Are these the numbers on the head that you need?
1953 Chevy 3100
Redbird,
Those numbers are not the actual "head" casting number. I believe they are often referred to as the "sand casting" number used as the base for the specific head casting to be made from.
The actual "head" casting number is located on the top surface of the head, drivers side near center of head just outward of the valve cover.
Below is a link (original source credit given to Tim's Trucks) from another Stovebolt thread that provides a great deal of pictures and info on where to locate engine block/cylinder head casting numbers, casting date codes and original serial number placement.
http://www.1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
Once you have all this information, there are other links (use the "Searching the Site" link in the forums left margin) that will help you identify what you actually have.
Let is know what you figure out.
Dan
~ Dan
1951 Chevy 3 window 3100
