2 members (walter74, 1 invisible), 102 guests, and 1 robot.
Topics128,049
Posts1,055,675
#1460293 07/26/2022 1:48 PM
Moderated
Moderated
Hello
My name is John, I have a 1951 3100 pickup truck.it is mostly stock. I replaced everything related to the brakes. Master cylinder, lines,hoses, etc,.. my problem is sometimes the brake pedal gets extremely hard to push and the brakes are dragging. I thought maybe I had filled the fluid to high so I took some out. Seemed to be better, then it happened again. ( it seems to only happen when my wife drives, it is her truck, I’m sure that has nothing to do with the problem). After it sits for a couple of hours it goes back to being ok. Seems like fluid builds up psi and is not returning back to MC. Any thoughts? I’m new to this forum, I’m glad to be here!
Thanks John
Jjs
John s #1460310 07/26/2022 4:45 PM
John,
Are you sure it isn't like the woman who complained about terrible fuel mileage, and after much searching, the mechanic rode with her to discover she pulled out the choke and hung her purse on it? grin (Sorry I couldn't resist.)
Have you looked at the wheel cylinders and shoes? Maybe something is hanging up there, or there's oil contamination on the linings.
John s #1460312 07/26/2022 4:58 PM
AD Addict & Tinkerer
Welcome to the ‘bolt! I have a ‘52 3100 with manual brakes and compared to today’s trucks, the pedal is hard. Mine doesn’t change though indicating something is wrong.
Just so you know, you will get more responses if you post in the Driveline Forum.
Good luck and see you around the Garage!
Phil
Project Journals
Stovebolt Gallery Forum
John s #1460326 07/26/2022 6:38 PM
Welcome John,
I would check your toeboard clearance;
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0508.htm
If this is not adjusted correctly, the master cylinder may not be returning to the "resting position" which allows the system pressure to return to zero. That will result in a hard pedal and dragging brakes. I am certain it is not because of your wife and how she drives it! Good luck,
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
John s #1460350 07/27/2022 12:38 AM
Welcome to the 'bolt.. i'm moving this to the Driveline forum where you will get the attention you need.
Another quality post.
Real Trucks Rattle
John s #1460359 07/27/2022 2:08 AM
Welcome wave
I agree with Kent! The MC piston is not returning all the way keeping pressure in the lines...make the adjustments per the manual...there should be a little pedal movement (free play) before you feel it moving the MC piston.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Originally Posted by Lightholder's Dad
Welcome John,
Kent
This is exactly what the problem was that I had with mine, very simple adjustment and I've had NO brake drag issues!
Doyle
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
John s #1460474 07/28/2022 1:09 PM
Welcome to Stovebolt. Consider yourself at home!
John s #1462106 08/10/2022 4:28 AM
thankyou everyone for your help i adjusted master and now so far i dont have brake fliud in boot as well.might be two issues. so i may take new master off and check piston cups
