0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | OKAY SO I NEED A CAB FOR MY 1/2 TON GMC RESTORATION PROJECT ,,,BUT DO I SACRIFICE A ONE TON CHEVY THAT CAN BE SALVAGED,,,CAN GET IT FOR SIX BONES...... | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | As long as you pass the remaining good stuff along it would be resurrecting a couple of trucks, Scott | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | That or do a little work on it and turn it over for a little more money,and buy a good cab. Speed | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Dashes are different. Changing them is a PITA. You could use a "fleet option" GMC gauge cluster - it's the same as the Chebby "V" cluster, but has a GMC logo at the bottom. | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | thanks guys,,,by the time i get the rusty thing home i would be in it for 1000.
so i am passing if anybody wants a chevy one ton with hoist.... | | |
