0 members (),
311
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 23 Junior Member | | Junior Member Joined: Sep 2005 Posts: 23 | Here is the number off the block. this block has a screw on oil filter on the block 8921967 GM
The other side is GM 19 19670 H
The Block is machined and comes with a machined head, new crank/ with rust, new Cam/with rust , pistons rings like new and bearings/rings in box. The motor has no corrosion in the cylinders but the area where the head sits has corrosion on it. The cam is cover in rust and so is the crank. I was told that it was ready for assembly. I have no distributer, could I use an HEI dist. in this block or should I stick to the old points style?
I did find a 47 GMC 2 Ton, under the hood is a 270 that was rebuilt but not sure how many miles on the motor. The motor looks really clean for just sitting the last 8 years.
Thanks for any input! Im sure I may have left some info out of my discription of the block. Let me know if you need any more info. If you know where I can get a Distributer let me know.
Later
You thought I drove a Ford! Where is my cresent wrench, I would like to adjust your thought pattern.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what motor is it supposed to be? 6 cyl I assume? not on the inliners list , but you may find other identifiers there, like head number seems like the guy that said it was ready to assemble oughta have a good idea of what it is, or more particularly the shop that did the machining - or that will do the re-machining, to get rid of the rust! Bill | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | 8921967 isn't on the list, but 3921967 is. That would be for a '64-'69 230 according to Inliners.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Sep 2005 Posts: 23 Junior Member | | Junior Member Joined: Sep 2005 Posts: 23 | Thanks! Now I know it's is an inline 6 cylinder 230 block, will it be a simple swap of parts from the old 235 babbet motor to the new motor? I did find pistons, rings, beaings in a box along with the crank, cam and head but I am missing the intake, distributer, fuel pump, Carb and other parts to get it running. The machine work was done on the block 30 years ago, I am afraid that the person who started this project was not availiable to comment on what was done.
ND Loadmaster
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | If you are talking swaping any parts from the 230 to 235, WON'T WORK! These are two different animals.
Also what type/year vehicle are to looking to stuff this new found motor into? If it's a pre 63 Chev you'll need the 216/235/261 or similar vintage GMC. 63 and later Chevs were 230/250/292 modern and totally different than 235. | | | | | Joined: Sep 2005 Posts: 23 Junior Member | | Junior Member Joined: Sep 2005 Posts: 23 | I have a 48 1 1/2 ton Loadmaster. I did find a 47 GMC motor 270. It looked like it would bolt right up.
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I think the 270 would be the way to go. It still isn't quite a bolt in,but is is a very easy conversion compared to the 230. Speed | | |
