5 members (RoadsScholar, dt235sd, JoergK., carbking, 1 invisible), 359 guests, and 5 robots.
Topics128,164
Posts1,057,079
Members48,463
Junior Member
Junior Member
Here is the number off the block.
this block has a screw on oil filter on the block
8921967
GM
The other side is
GM 19 19670
The Block is machined and comes with a machined head, new crank/ with rust, new Cam/with rust , pistons rings like new and bearings/rings in box. The motor has no corrosion in the cylinders but the area where the head sits has corrosion on it. The cam is cover in rust and so is the crank. I was told that it was ready for assembly. I have no distributer, could I use an HEI dist. in this block or should I stick to the old points style?
I did find a 47 GMC 2 Ton, under the hood is a 270 that was rebuilt but not sure how many miles on the motor. The motor looks really clean for just sitting the last 8 years.
Thanks for any input! Im sure I may have left some info out of my discription of the block. Let me know if you need any more info. If you know where I can get a Distributer let me know.
Later
You thought I drove a Ford! Where is my cresent wrench, I would like to adjust your thought pattern.
what motor is it supposed to be? 6 cyl I assume? not on the inliners list , but you may find other identifiers there, like head number
seems like the guy that said it was ready to assemble oughta have a good idea of what it is, or more particularly the shop that did the machining - or that will do the re-machining, to get rid of the rust! grin
X
X Offline
8921967 isn't on the list, but 3921967 is. That would be for a '64-'69 230 according to Inliners.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
Junior Member
Junior Member
Thanks!
Now I know it's is an inline 6 cylinder 230 block, will it be a simple swap of parts from the old 235 babbet motor to the new motor?
I did find pistons, rings, beaings in a box along with the crank, cam and head but I am missing the intake, distributer, fuel pump, Carb and other parts to get it running.
The machine work was done on the block 30 years ago, I am afraid that the person who started this project was not availiable to comment on what was done.
ND Loadmaster
If you are talking swaping any parts from the 230 to 235, WON'T WORK! These are two different animals.
Also what type/year vehicle are to looking to stuff this new found motor into? If it's a pre 63 Chev you'll need the 216/235/261 or similar vintage GMC. 63 and later Chevs were 230/250/292 modern and totally different than 235.
1946 1/2-Ton Chevy
Junior Member
Junior Member
I have a 48 1 1/2 ton Loadmaster. I did find a 47 GMC motor 270. It looked like it would bolt right up.
I think the 270 would be the way to go. It still isn't quite a bolt in,but is is a very easy conversion compared to the 230.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
