Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (klhansen, 1955 1 Series, CuzzFuzz, Wally / Montana, 1 invisible), 57 guests, and 3 robots.
Topics128,003
Posts1,055,243
Members48,418
#1451719 05/15/2022 4:22 PM
This stuff is available locally to me. Is any of it useful in putting a later model automatic behind my '54 3100 235 ?
The simple answer would be no. The adapter plate and the rearmost transmission appear to be for a 235 and an early Powerglide.
It's questionable that the adapter could be used with any later transmission.
The other transmission appears to be a later unit which possibly could be used with the proper adapter. The flywheels and clutches would be of no help for any automatic conversion.
Fred
There are modern adaptors out there to go modern automatic for your '54. Check out Langdon's Stovebolt Engine Co. www.langdonsstovebolt.com, ph 586 739-9601
http://www.langdonsstovebolt.com/tech/transmission-update/
1946 1/2-Ton Chevy
Thanks, I was thinking that stuff might be early powerglide stuff but I know ZIP about Stovebolt automatic lore.
Curmudgeon
Curmudgeon
The way you learn the "lore" at Stovebolt is to start with a steel brush and clean the crud off the casting numbers.
Record the numbers. If you have a PDA, PMD, other handheld gadget or regular computer, see if you can get a hit on the net.
Also try http://www.gmpartswiki.com. Do a specific search (in quotes) here on Stovebolt or other sites.
Take measurements. This is what most people do.
When you get stumped, post your questions with as much information as you can provide.
I have a Langdon 235 adapter plate for sale if you are interested
1954 3100 with Hydra-Matic
Currently undergoing S10 conversion
Parkinson’s...it’s not just for the elderly
Caution, slow man at work
Curmudgeon
Curmudgeon
No Longer Available (14 July 2022)
I'm not selling this adapter. I just happened to have a cut-n-paste of Langdon's old web page.
The price is out of date anyway. The picture is FOR REFERENCE ONLY.
Other than the original 4 speed Hydramatic or Powerglide, does anyone have an automatic on a 235 engine that they are happy with?
Before I decided to go with the S10 conversion, I was going to install a 700r, non-computer. IMO, better than a PG and TH
A little side note. I searched online for trans dapt and when I opened Amazon there it was. just 2 minutes later.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
