7 members (Gdads51, GrandpasJimmy, SmalltownTRKGuy, Jon G, Otto Skorzeny, Bill Trotter, Bill Hanlon),
108
Mod | | | Forums66 Topics128,194 Posts1,057,248 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Well, my vendor sent me unpolished bed angle strips and not the steel angle strips I actually ordered. I didn't open the box for 8 months and I'm stuck with them. With shipping and the cost of reordering I need to make these work. I'm competent with my MIG welder with 75% / 25% Argon Co2. What do I need to know? I figure I'll have to rough them up to get paint to stick to them so discoloration from welding is not an issue with me. Stainless is 430 . Help!
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Dusty, can you sandblast them...or someone that can. It'll give them enough tooth that the paint will stick. | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Well after researching the welding and determining I need to get the correct filler wire, and then the time, travel , trial and error involved , I said to heck with it and ordered a set of steel angle strips from another vendor who had them in stock. I'm pretty sure I'd spent more money on just the filler wire and the gas to go get it....
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: May 2015 Posts: 11,167 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,167 | You've already decided on a solution, but you could probably have someone spot weld the angle strips to your bedsides. The discoloration at the spot welds can be polished out with a wire brush on a rotary tool. Maybe post he stainless strips in the Swap Meet in case anyone wants them.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | I simply plug welded the strips to the bed, scuffed them down with 80 grit, then painted. Seems to be holding up fine…
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
| | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | You've already decided on a solution, but you could probably have someone spot weld the angle strips to your bedsides. The discoloration at the spot welds can be polished out with a wire brush on a rotary tool. Maybe post he stainless strips in the Swap Meet in case anyone wants them. Kevin, good idea. Funny thing, the "shipping cost" varies greatly by supplier as does the cost for these angle strips.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I have no holes on my strips to mount to the bed side. I assumed I would need to drill and bolt to the bedside?
Are these supposed to be welded like OEM or can they be bolted? | | | | | Joined: Sep 2010 Posts: 2,334 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,334 | They can be welded they .you can drill a hole in the box side and weld from the outside leaving the strip solid .On my 54 box side all but one hole is covered by the fenders or box side pocket .I think there is a write up on the mar k site. | | | | | Joined: May 2015 Posts: 11,167 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,167 | On the ends where the stake pockets are, you'd have to drill the angle strip and weld from the inside, unless you are better than me at getting a MIG gun inside the stake pocket.
