0 members (), 125 guests, and 6 robots.
Topics128,186
Posts1,057,211
Members48,465
Hi All,
My pads probably should be replaced on front.. While I am at it.. might replace drums.. Anyone know where I can get these? Anything local in Maryland? wave
'38 1.5ton; "The stuff is as tough as woodpecker lips"
Former Workshop Owner
Don't toss your old shoes and drums. Most likely you will need to get the shoes relined and the drums turned. I doubt those items are being manufactured anymore.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
I have linings if you have someone who can rivet them onto your old shoes. I can rivet them also but shipping both ways would be more expensive than having it done locally.
Mike
1936 1-1/2 Ton (RD) Stake Body Original
C Online: Content
I bolted a lot of pads to brake shoes 50 to 60 years ago. The bolts can still be bought.
https://www.lawsonproducts.com/lawson/Brass-Brake-Shoe-Bolt-38-16/1450A.lp
Later we switched to rivets. Brakes use a hollow shank rivet and we were accustomed to working with rivets anyway. They weren't any better, but they were much quicker.
As for the drums, hold on to them. There is a good chance that you won't be able to find new ones and you will have to turn your old ones.
Ok thanks guys! So i could just use those bolts in the link? Shoild i use any of the red or blue locktight? Also, i heard some places can actually make new replica drums if they have the originals.. in case mine are too worn, anyone heard of that?
Most anything can be replicated. It's usually a matter of how much one is willing to pay.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
Okay.. how about lining tbe original drums? #creative. ? Anyone done that? I really want to keep as much original i can. Thanks
There's a process called metallizing (IIRC) that sprays molten metal on a surface to build it up. I saw a thing where Ford was "resleeving" cylinders on 7.3L diesels using the process. If it works for cylinder walls, it would surely work on brake drums. But $$$$.
I have done business with a company that spray welds. We've used them a couple times for various projects. Might give them a call.
Metallic Bonds 608-365-9299 800-236-3307 fax 608-365-2264
1929 Royce Ave Metallicbonds.com Spray Welding
Beloit, WI 53511
Good luck.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
C Online: Content
The bolt come with external tooth lock washers. But if it would make you feel better blue or even red thread locker wouldn't hurt anything. You are probably never going to take it apart again any way.
Thanks guys! Well i plan to drive it.. maybe 3-4,000 mes a year..
