1 members (NJC), 132 guests, and 2 robots.
Topics128,162
Posts1,056,941
Members48,458
I am in the process of taking off all brake drums to rebuild brake system. Front drums are off but can not get the rear drum/hub to come off truck.
Is there a trick I am missing? This subject was covered before but I'm still lost as how to remove these from the truck. Any help would be appreciated.
Don Mims
Cumming, Ga
Don, I have a 51 1.5 ton. there are 3 slotted screws that hold the drum to the hub.
1951 1.5 ton 4400
Don, Will the drum turn?
1951 1.5 ton 4400
Yes the drum turns. I've been driving around without brakes. I need to replace the wheel cylinders. I was told to remove the hub cover and pull the axle out. Then remove the lock ring and two lock nuts and the brake drum comes off. Hope this works.
Thanks. This is a new adventure for me.
Don
Don,
Doing what you described takes more than just a claw hammer and pair of pliers...hope you have some big stuff.
Stuart.
Socket Breaker
Socket Breaker
Uhm - I dunno about the big bolts but on the 1/2 tons from that era - to get the drum off ya hadda take the whole thing apart from the back - cuz of those slotted screws greg1.5 mentioned... it is quite aggravating as I understand it.
-W
Don,
You don't have to remove the hub to remove the drum. As Greg1.5 said, there are screws in the face of the drum holding it to the hub. Remove them and back off the adjusters if the drum hangs up on the shoes while trying to remove. I have also had to put a big pry bar between the backing plate and the drum and while pulling the pry bar thump the side of the drum with a big No-Bounce hammer. They won't fall off like a car drum will, you have to work them off!
Good luck!
Mike smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
On both of my 48 1.5 tons, you do have to remove the drums. There are no screws on a 48,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Oops! I thought the AD rears were the same as the TF rears. Guess I was wrong.
Thanks for keeping me straight Scott!
Mike B. smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
You are partially correct Mike. On the '47-'50 1 1/2 & 2 ton trucks, the drum, & hub, are removed together. On the '51, & up 1 1/2, & 2 ton trucks, you do indeed, remove 2 slotted screws, then remove the drum, from the hub.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
