3 members (Nick in Manitou, Wally / Montana, 1 invisible), 58 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
#144542 10/10/2005 1:46 AM
Hi gang,
Just did a few updates to the shop tools page and the disassembly page on www.chevyc60.com ...
More updates will be coming soon...
Thanks...and happy viewing...
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
#144543 10/10/2005 1:53 AM
Way ta go Burgie, Good Stuff!
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#144544 10/10/2005 4:12 AM
Former Workshop Owner
Nice job on everything. I also built an engine hoist, tow bar, several garages and a shed. (Over the course of a few years anyway).
You did a very professional job on them all. You obviously have a good eye for detail.
I am just curious, what type of rock is your truck parked on? Is that a dark crushed granite, or something else? Also, why did you build two sheds instead of one larger one?
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#144545 10/10/2005 4:17 AM
Burgie,
Beautiful stuff and a class act web site! You have gathered a ton of great information on the '60s bolts and have it all organized and presented professionally..Bravo. smile
Stuart.
#144546 10/10/2005 4:42 AM
J Lucas,
Thanks for the kind words smile smile .
Yes, the rock is crushed blue granite. We are in the process of Xeriscaping (spelling??) our whole yard and my wife and I like the contrast of the blue granite next to the lava rock and larger diameter river rock border.
I chose to build 2 sheds because the building codes out here in the Colorado Springs area says that the maximum size of a shed without a permit is 10'x12'. My sheds are 8'x12'...the 8' dimension merely to coincide with 8' sheet goods.
I built the doors using mortise and tenon contruction from pine stock I had milled several years earlier from large logs. The panels are AC grade plywood; I machined "V" grooves in the face for an "old" decorative look.
I've been swinging a hammer since 3rd grade as Dad was a general contractor. There isn't much in terms of residential construction that I haven't done. I'm thankful that Dad is such a well rounded craftsman skilled in a variety of disciplines...and a good teacher.
One of these days I'll be building a 28' x 40' shop to house all my woodworking tools and machines as well as my mechanic tools and yes, of course, my dump truck.
Again, thanks for the kind words!!!
Burgie
#144547 10/10/2005 5:14 AM
Hi Stu...
Ditto...thanks for the kind words smile smile ...
With the first snow in Colorado now falling (yes, it is snowing here in Falcon) I have a feeling it'll be a long winter. I have so many things I want to add to my site but simply haven't had time. Further, it's hard to sit in front of the PC in the summer when you could be outside working on the truck smile smile .
Nevertheless, I hope to be adding a chat forum, more procedural flows, more specs, links and reader's trucks...
Thanks again Stu...
Burgie
#144548 10/18/2005 12:49 PM
Socket Breaker
Socket Breaker
nice tools Burgie. I remember seeing the engien hoist before - I like the tow bar and the sheds, neat.
yer truck is still cool also... smile
wow - look at all the pictures of the truck in pieces! grin
you have out done yourself Burgie.
-W
#144549 10/18/2005 6:13 PM
Burgie,
My old rig is a 55/1st 4400 with a 12' flatbed. Soon after I purchased it I pulled the 235, bought a 350 and did a "test fit". It looked like there was no way the steering box could remain where it was, special headers or not! I tried to visualize what type of box I could put in and where it could go...then I came to my senses and scrapped the V-8 idea and went back to the old 6 banger.
I looked through your "disassembly" photos last night and lo and behold, the steering box on your old yellow dump truck is the one I visualized as a swap on my old truck...WOW. It sits ahead of the axle and the drag link goes BACK to the steering arm. This moves it out of the engine area. I will stick with my stock engine, but for others contemplating this swap, your vintage steering setup might be a option.
Stuart.
#144550 10/22/2005 8:38 PM
Socket Breaker
Socket Breaker
Burgie - I emailed ya at the email listed on yer webpage... do you check that one at all?
-W
#144551 10/23/2005 1:56 AM
Hi Woogeroo,
Yes, I received your mail. Sorry for the late response; work has me running insane these days :mad: :mad:
OK, if you are running Internet Explorer you should be able to see the navigation toolbar at the top of each of my pages.
If not, you can download and install Java Runtime Environment for Windows and that should fix your problem.
Try it out and let me know if things work out...
Burgie
#144552 10/23/2005 11:57 PM
Socket Breaker
Socket Breaker
Ah. it seems I had java turned off on this computer's IE as I was trying to track down an issue awhile back... never turned it back on. hah.
-W
#144553 10/24/2005 1:22 AM
Good stuff Woogeroo...glad it was something simple smile smile
Burgie
