9 members (GMCJammer51, Materman, Lightholder's Dad, Ridgeback, Brian Moore, tclederman, jupitor, treegrower, 1 invisible),
189
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Way ta go Burgie, Good Stuff! | | | | | Joined: Nov 2004 Posts: 2,407 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,407 | Nice job on everything. I also built an engine hoist, tow bar, several garages and a shed. (Over the course of a few years anyway). You did a very professional job on them all. You obviously have a good eye for detail. I am just curious, what type of rock is your truck parked on? Is that a dark crushed granite, or something else? Also, why did you build two sheds instead of one larger one?
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Burgie, Beautiful stuff and a class act web site! You have gathered a ton of great information on the '60s bolts and have it all organized and presented professionally..Bravo. Stuart. | | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | J Lucas, Thanks for the kind words  . Yes, the rock is crushed blue granite. We are in the process of Xeriscaping (spelling??) our whole yard and my wife and I like the contrast of the blue granite next to the lava rock and larger diameter river rock border. I chose to build 2 sheds because the building codes out here in the Colorado Springs area says that the maximum size of a shed without a permit is 10'x12'. My sheds are 8'x12'...the 8' dimension merely to coincide with 8' sheet goods. I built the doors using mortise and tenon contruction from pine stock I had milled several years earlier from large logs. The panels are AC grade plywood; I machined "V" grooves in the face for an "old" decorative look. I've been swinging a hammer since 3rd grade as Dad was a general contractor. There isn't much in terms of residential construction that I haven't done. I'm thankful that Dad is such a well rounded craftsman skilled in a variety of disciplines...and a good teacher. One of these days I'll be building a 28' x 40' shop to house all my woodworking tools and machines as well as my mechanic tools and yes, of course, my dump truck. Again, thanks for the kind words!!! | | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Hi Stu... Ditto...thanks for the kind words  ... With the first snow in Colorado now falling (yes, it is snowing here in Falcon) I have a feeling it'll be a long winter. I have so many things I want to add to my site but simply haven't had time. Further, it's hard to sit in front of the PC in the summer when you could be outside working on the truck  . Nevertheless, I hope to be adding a chat forum, more procedural flows, more specs, links and reader's trucks... Thanks again Stu... | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | nice tools Burgie. I remember seeing the engien hoist before - I like the tow bar and the sheds, neat. yer truck is still cool also... wow - look at all the pictures of the truck in pieces! you have out done yourself Burgie. -W | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Burgie, My old rig is a 55/1st 4400 with a 12' flatbed. Soon after I purchased it I pulled the 235, bought a 350 and did a "test fit". It looked like there was no way the steering box could remain where it was, special headers or not! I tried to visualize what type of box I could put in and where it could go...then I came to my senses and scrapped the V-8 idea and went back to the old 6 banger.
I looked through your "disassembly" photos last night and lo and behold, the steering box on your old yellow dump truck is the one I visualized as a swap on my old truck...WOW. It sits ahead of the axle and the drag link goes BACK to the steering arm. This moves it out of the engine area. I will stick with my stock engine, but for others contemplating this swap, your vintage steering setup might be a option.
Stuart. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Burgie - I emailed ya at the email listed on yer webpage... do you check that one at all?
-W | | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Hi Woogeroo, Yes, I received your mail. Sorry for the late response; work has me running insane these days :mad: :mad: OK, if you are running Internet Explorer you should be able to see the navigation toolbar at the top of each of my pages. If not, you can download and install Java Runtime Environment for Windows and that should fix your problem. Try it out and let me know if things work out... Thanks | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Ah. it seems I had java turned off on this computer's IE as I was trying to track down an issue awhile back... never turned it back on. hah.
-W | | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Good stuff Woogeroo...glad it was something simple  | | |
