0 members (),
64
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | This seems so elementary that asking it is embarrassing, but here goes. I don't know how to put a motor on an engine stand. If I take everything off the engine the bolts I would use to fasten it to the stand seem much too small. Is it the normal procedure to leave the bell housing on the motor and them fasten that to the stand? Again, thanks for the help. Allen | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | The bell housing has to come off. The engine block attaches to the engine stand. (Assuming there is generally one type of stand and it is like the two I own.)
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | All the engine stands i've ever owned had this "X" looking thing that got bolted right to the back of the block.
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Both of mine have the four adjustable "X" arms. I use grade 8 bolts and washers to hold the block in place. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Be sure to get as much thread into the block as you can.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Originally posted by Pakrat47: Be sure to get as much thread into the block as you can. No doubt! Using the "two threds in" method would be a recipe for some squashed toes and a flat oil pan!
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The old stovebolt 6,s are hard to put on my engine srand. I had to make a bracket to extend the arm over to the block. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Mine fell off and actually landed smack down on the oil pan and stayed standing upright. Now I need a new oil pan and who knows what else..........Darn glad my feet were not under it! Since then I took a moving cart and shored it up and the engine sits on that now until I get my frame finished enough to put it back in it.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | Just get some good grade 8 bolts that will go throught the engine stand,and have enough threads to go into the block at least as far as the bellhousing bolts did.Have a few washers on hand as well,just in case you need to make up a difference in distance between the block and stand. | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I didn't like how the long six cylinder block wobbled on the stand Dad made, which has at least twice as much iron as the commercially available stands I have seen recently.
I revamped the brackets and the engine sits on the stand sideways. I'll take some pics and post them if there is interest. | | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | And remember...center the engine on the stand so its not top heavy, otherwise, when you go to flip it over....
Not that Ive ever done that....honest. | | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Thanks guys. I finally figured it out. Like most things, once you know how it works it seems so simple you wonder why you didn't see it to begin with. Allen | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Tim; You're lucky yours messed up the oil pan;I used the "heavy duty Grade 5" bolts that came with my stand (used) and found my 348 face down the next morning,with a broken crank. Not a good thing. Now I use grade eight bolts,longer than I need,then I stack washers under the head of each bolt until there's just enough threads to tighten before bottoming out. Yeah,it's overkill,but I don't mind,considering the alternatives. I also drilled a hole in the plate to enable me to install a pilot bushing with the engine on the stand,just so I won't forget it once I get the engine on the hook again. Speed | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Tim; You're lucky yours messed up the oil pan;I used the "heavy duty Grade 5" bolts that came with my stand (used) and found my 348 face down the next morning,with a broken crank. Not a good thing. Now I use grade eight bolts,longer than I need,then I stack washers under the head of each bolt until there's just enough threads to tighten before bottoming out. Yeah,it's overkill,but I don't mind,considering the alternatives. I also drilled a hole in the plate to enable me to install a pilot bushing with the engine on the stand,just so I won't forget it once I get the engine on the hook again. Speed | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Originally posted by speed: Tim; You're lucky yours messed up the oil pan;I used the "heavy duty Grade 5" bolts that came with my stand (used) and found my 348 face down the next morning,with a broken crank. I still have that fear because it looks like the first point of contact was the front pulley. It does still turn nicely by hand though. I think I'll just puke if it is worse than just the pan. As you can see if you look close, I had it pretty much ready to go. [img] http://www.sheridanzone.com/images/46chevy/engine.jpg[/img]
