2 members (78buckshot, NJC),
99
Mod | | | Forums66 Topics128,149 Posts1,056,819 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | Son has a 54 DRW 3800. Also a SRW 3600 chassis with new brakes all the way around. Wheels I have clear the 3600 rear end but not the 3800 (late model 16ā GM). Can I simply swap backing plates, hardware, drums, etc? Your guidance is appreciated! | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Are you planning on doing real truck stuff, or building a Cowboy Cadillac? There's a reason a 1 ton has bigger brakes than a 3/4 ton. Jerry
| | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | How about half way in between. Not enough to need 1 ton brakes.If I wanted a cowboy Cadillac Iād put a disc brake swap and an LS in it. | | |
