8 members (Wayne67vert, TUTS 59, Hotrod Lincoln, Otto Skorzeny, klhansen, Shaffer's1950, Dragracefan, fonz8261), 172 guests, and 2 robots.
Topics128,165
Posts1,056,992
Members48,458
#1442902 02/28/2022 12:17 AM
Son has a 54 DRW 3800. Also a SRW 3600 chassis with new brakes all the way around. Wheels I have clear the 3600 rear end but not the 3800 (late model 16ā€ GM). Can I simply swap backing plates, hardware, drums, etc? Your guidance is appreciated!
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
H Online: Content
Are you planning on doing real truck stuff, or building a Cowboy Cadillac? There's a reason a 1 ton has bigger brakes than a 3/4 ton.
How about half way in between. Not enough to need 1 ton brakes.If I wanted a cowboy Cadillac I’d put a disc brake swap and an LS in it.
Moderated by  Dusty53
