8 members (Rusty Heaps, Frank50, BarryP, UtahYork, cmayna, DadsFirstPickup, Gray_Ghost, 1 invisible),
138
Mod | | | Forums66 Topics128,134 Posts1,056,738 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 10 New Guy | | New Guy Joined: Jun 2005 Posts: 10 | I've had the rear apart for a brake job. There are three parts that ought to be new when I put it back: the aluminum gasket at the axle flange, the lock plate for the 8 cap screws (little lock tabs are all broken off), and the spider-like lock that holds the wheel bearing nuts in adjustment (necessary legs also broken off). Does anybody know of a source for these parts? Can I replace the aluminum gasket with some new gasket material that I could cut myself? I can't wait to actually drive this thing out of the garage. Thanks, Joe H. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Most any truck shop will have the lock tabs. As for the gasket, just dry it good and use some silicone sealer and put some lock tight on the bolts so they will stay locked down too, Scott | | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | There is a few Fleet pride truck parts stores in ct. Hartford,Waturbury and North haven. They will have what your looking for. Just bring the old parts with you | | | | | Joined: Jun 2005 Posts: 10 New Guy | | New Guy Joined: Jun 2005 Posts: 10 | | | |
