| | | Forums66 Topics128,089 Posts1,056,130 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 51 | Hey guy's I'm new to the forum Just aquired a Canadian made '46 GMC 2 Ton, has any one swapped a body and cab over to a newer GM half ton frame? I appreciate any advice... | | | | | Joined: Aug 2005 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 51 | Maybe a little more info before you write me off, the existing frame is baddly twisted I'm just trying to keep the spirit of my '46 alive. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The front fenders and wheel openings were enlarged to fit the 20" wheel of the big trucks. Using that body on a 1/2 ton frame would be way out of proportion. Transplant your body to an old diesel delivery truck with a modern drivetrain would be a cool way to salvage your body. There's my 2 cents, Scott | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The cabs were all the same size, right? so all he's need to do is get fenders? Or would he need a whol;e front clip (fenders hood grill)
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | just the fenders - but the deco cabs are narrower than anything newish, and will be hard to fit to any 1/2 or 3/4T - maybe an s10
Bill | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've seen this done two ways. Check Sublime's post in the general forum; he widened his fenders a couple inches to cover the wheels on a four-wheel-drive chassis. Sublime Winged Express narrowed an IFS crossmember to fit a Advance Design big bolt frame and fit under an Art Deco's fenders. WingedExpress
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
