0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Saw an episode on youtube where a builder cut down his fan blades by an inch. He then mounted them in place and the motor ran smoothly. I was of the impression that once you removed metal from a fan blade it should be balanced. Seems strange. Spoke to my neighbour who is an expert on everything and he said balancing was unnecessary. He is a nice guy but unless he knows the answer he will make up one. He also broke two crankshafts on his diesel Land Cruiser over the years. He is now on his fifth rebuild. | | | | | Joined: May 2015 Posts: 11,060 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,060 | If you cut the same amount off of each blade, then there probably wouldn't be a need to rebalance it. The outer portion of the blade has the most effect on balance, and if it was OK beforehand, it'll probably be OK afterwards. Now if you cut one blade out of 4, then it would definitely be unbalanced. I have a fan that one blade broke off and they cut the opposing blade off to get it back in balance.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | It’s done fairly frequently in the hotrod world. They use a template and etch a fine line with a scratch awl. Cut a little short and sneak up on the line with a abrasive wheel. No issues.
| | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | Poured or hammered metal has inconsistencies, so nipping a little off the edges could throw it out of balance but we can’t be too certain how balanced it was from the factory. If you put it back on and hear vibration I guess you’ll know.
1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: May 2015 Posts: 11,060 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,060 | Most fans are pressed sheet metal and any inconsistencies in thickness would be pretty minor. Again as long as the same amount is cut from each blade, then no problems.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | I won't even attempt to straighten a bent fan blade, let alone start whittling on one. Jerry
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I have a fan that one blade broke off and they cut the opposing blade off to get it back in balance. The same thing happened years ago on the '46 truck my Dad had. Ran it for years with a 2 bladed fan. | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | I would have to agree with Jerry. Fan blades can come apart, and you don't want to be in the area when they do. Jim | | | | | Joined: Sep 2013 Posts: 1,362 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,362 | I would have to agree with Jerry. Fan blades can come apart, and you don't want to be in the area when they do. Jim Yep, my in his 30's cousin did a total nut and bolt down to bare frame on a M38 Jeep. Built a nice Buick V6 for it and it was a nice rig. While leaning over the front and with a hand on the throttle linkage a fan blade came off. A few days later I was at his funeral. RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Back in the 1950's it was common for the dirt track racers to shorten the fan blades on flathead Ford race engines. One night in Nashville a blade broke off as a driver revved his engine up. It hit a pit crew member in the sternum and pretty well destroyed his rib cage. He survived, but he was never able to work again.
If you want a small diameter fan, buy one. Jerry
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Had a fan blade come off my '60 way back in 1970's. It went down, put a small nick in the l.h. frame rail. Vibrate you off the road.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2007 Posts: 3,386 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,386 | I had a flex fan ruin the hood on a freshly painted 57' Belair. No more flax fans...
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | Cutting blades shorter should have nothing to do with it coming apart. If it's coming apart, it will do it with longer blades due to the mass, short blades have less. Use a lawn mower blade balancer once you start cutting them shorter.
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Draw to an inside straight in a poker game- - - - -those odds are only 32:1 against you! Jerry
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Sedgewick In the olden days if you lost 1 blade you had to break off the opposite one just to get home,cause it shook so bad ! | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I would have to agree with Jerry. Fan blades can come apart, and you don't want to be in the area when they do. Jim Had one come through the hood of my 69 (Not Chevy). I twisted that engine over 8K and it shot a blade right off the fan. Wish it would have gone down vs up, but it was a fun discussion every time.
| | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | I realize this is an old post but thought I would add to it In 1958 Chevrolet issued a "RED" memo warning not to rev the 348 with three dueces while sitting still for fear of a fan blade exploding. Since then I have seen two case of stove bolts launching fan blades thru the hood, both with no modifications. So it has been my practice to never stand in line with the fan when running an engine. Hope this keeps someone from getting hurt. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Works for aircraft propellers, too!
Ed
