5 members (Southerntruck, Wally / Montana, Gray_Ghost, Steelonsteel, 1 invisible), 86 guests, and 0 robots.
Topics128,050
Posts1,055,761
#142771 04/21/2005 2:15 AM
Got my 37 1 1/2 ton out for the first time this spring [fired right up!] and noticed that my rear axle seal had leaked a bit over the winter on the right side. Is it possible to remove the seal and run a bead of silicone on it and put it back in. As I remember that seal was a felt type deal with metal on the outside. If I need to get a new seal, who would have one? Thanks for your help in advance!
#142772 04/21/2005 2:32 AM
I just got two new ones today for my '48 1 1/2 ton from Carquest. They actually had them in stock. I think it's the same rearend they used for many years. What you may have to do is take your old one out and find the part number on it and see if a parts guy can cross reference it to a modern number or measure it up and find a match to it.
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#142773 04/21/2005 10:36 PM
Riding in the Passing Lane
If you are refering to the axle flange gasket its probably available. You can put silicone sealer on it instead.
1972 Chevy c10 Cheyenne Super
#142774 04/22/2005 3:09 AM
clarification please, if it's the outer seal axle to hub I agree with wrenchbender if it's inner seal hub to axle housing replace it.now that I've come down firmly on both sides perhaps a career in politics is next.
#142775 04/22/2005 4:55 PM
It is that outer axle flange seal and I will give it the silicone treatment. Next winter when I get around to relining the brakes I will replace with new seals. Thanks everyone- Get out and enjoy the Big Bolts!
