7 members (klhansen, Hawkman, mason86, mick53, festerhairball, UtahYork, 2-Ton), 100 guests, and 2 robots.
Topics128,069
Posts1,055,886
Members48,428
#142757 09/12/2004 4:31 AM
Hi folks,
Can anyone tell me what this is ??
It's connected to the bottom of the master cylinder, so obviously it has something to do with the brakes...but what? It definitely looks like an aftermarket item...
Thanks, in advance!!
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
#142758 09/12/2004 4:35 AM
Its a brake lock unit. I use to have one on my old Dodge truck.
Joe
#142759 09/12/2004 8:26 AM
more like electric trailer brake unit. brakelocks are hydraulic from my experiance (mico lock, etc.) sure looks electric to me.
#142760 09/12/2004 2:59 PM
I second the trailer brake control post,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#142761 09/12/2004 4:13 PM
Yep, I concur with the trailer brake unit. The units for older bigger trucks are actuated by a line that runs from the brake line into the unit and then sends an electrical signal back to the trailer brakes electrically.
~ One of many.
#142762 09/12/2004 7:23 PM
It's an old-style trailer brake control. The newer ones are inertial, and don't have the hydraulic line attached. It's for controlling electric brakes on a travel trailer, etc. If you try to use the control unit with the hydraulic line attached on an anti-lock brake system, it will disable the anti-lock feature. The hand knob is used to apply the trailer brakes only, without using the tow vehicle brakes, a good feature for dampening out a sway, etc.
#142763 09/12/2004 7:52 PM
OK...thanks gang smile smile
I am doing a restoration to original and kinda suspected that this wasn't a factory item...
Thanks again for the expert feedback...
By the way...what happened to "The Lounge"? I don't see it anymore??
Burgie
#142764 09/13/2004 5:03 AM
it went away. guess we leave it at that. back to the subject. you might think before you do away with the controller. i understand about the original equipment thing, but if you ever do pull a trailer those things are real handy. a trailer that's loaded too far back can sway and cause you to jacknife. that button is a damned good way to save your truck, or your life. just think about it. maybe you can hide it better, but still be able to use it.
#142765 09/15/2004 6:57 AM
I just put one like that on my '77 C-30. One panic stop with a loaded trailer was enough to motivate to get it hooked up.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
