1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Hi folks, Can anyone tell me what this is ?? It's connected to the bottom of the master cylinder, so obviously it has something to do with the brakes...but what? It definitely looks like an aftermarket item... Thanks, in advance!! | | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Its a brake lock unit. I use to have one on my old Dodge truck.
Joe
| | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | more like electric trailer brake unit. brakelocks are hydraulic from my experiance (mico lock, etc.) sure looks electric to me. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I second the trailer brake control post, Scott | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Yep, I concur with the trailer brake unit. The units for older bigger trucks are actuated by a line that runs from the brake line into the unit and then sends an electrical signal back to the trailer brakes electrically.
~ One of many.
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | It's an old-style trailer brake control. The newer ones are inertial, and don't have the hydraulic line attached. It's for controlling electric brakes on a travel trailer, etc. If you try to use the control unit with the hydraulic line attached on an anti-lock brake system, it will disable the anti-lock feature. The hand knob is used to apply the trailer brakes only, without using the tow vehicle brakes, a good feature for dampening out a sway, etc. Jerry
| | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | OK...thanks gang I am doing a restoration to original and kinda suspected that this wasn't a factory item... Thanks again for the expert feedback... By the way...what happened to "The Lounge"? I don't see it anymore?? | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | it went away. guess we leave it at that. back to the subject. you might think before you do away with the controller. i understand about the original equipment thing, but if you ever do pull a trailer those things are real handy. a trailer that's loaded too far back can sway and cause you to jacknife. that button is a damned good way to save your truck, or your life. just think about it. maybe you can hide it better, but still be able to use it. | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | I just put one like that on my '77 C-30. One panic stop with a loaded trailer was enough to motivate to get it hooked up.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
