| | | Forums66 Topics128,052 Posts1,055,726 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Right before the Lounge died someone was posting about parting out a C60. One of my hood hinge springs is broken and it is a bear on my back to lift the hood. Who was that with the truck? You mentioned I could get one of the springs out of your truck.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 |
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Wouldn't one from a pick-up fit? They should be easy to find locally, Scott | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | It had been an offer for a free part. What the Stovebolt is all about. I would contact the person direct if I remembered which member it was. It was in the Lounge, but, you know...not very searchable?
I thought a pickup spring would be the same but had been told the C60 has a bigger hood?
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Tony, I could swear I saw a C60, not a LCF, with a pick-up hood on it somewhere on the 'net. I drive a 64 C10 everyday and could easily go out and take a few measurements to verify if you would like. I would put them on as a pair if it does work out though. If you were closer, I would give as many as you would like, Scott | | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | The Hoods R The Same on the C60 as any other C or K series truck. I used a Pick up hood on the 1966 C60 Tow Truck I had. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I thought they were too, but when I posted before about my broken spring people were saying they are not the same. Man those years pickup trucks had big hoods. I guess I will look for a regular spring. Thanks [img] http://www.angelswest.com/_borders/dump1b.jpg[/img]
| | | | | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | | | |
