4 members (Peggy M, Gray_Ghost, Wally / Montana, 2-Ton), 106 guests, and 2 robots.
Topics128,052
Posts1,055,717
#142436 01/09/2005 10:55 PM
Right before the Lounge died someone was posting about parting out a C60. One of my hood hinge springs is broken and it is a bear on my back to lift the hood. Who was that with the truck? You mentioned I could get one of the springs out of your truck.
54 3100 with 235
62 flatbed dump C60 with 261
#142437 01/10/2005 1:15 AM
62401
Yellow zone, Tony.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
#142438 01/10/2005 2:07 AM
Wouldn't one from a pick-up fit? They should be easy to find locally,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#142439 01/10/2005 3:42 AM
It had been an offer for a free part. What the Stovebolt is all about. I would contact the person direct if I remembered which member it was. It was in the Lounge, but, you know...not very searchable?
I thought a pickup spring would be the same but had been told the C60 has a bigger hood?
54 3100 with 235
#142440 01/10/2005 5:12 AM
Tony,
I could swear I saw a C60, not a LCF, with a pick-up hood on it somewhere on the 'net. I drive a 64 C10 everyday and could easily go out and take a few measurements to verify if you would like. I would put them on as a pair if it does work out though. If you were closer, I would give as many as you would like,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#142441 01/10/2005 8:36 AM
The Hoods R The Same on the C60 as any other C or K series truck. I used a Pick up hood on the 1966 C60 Tow Truck I had.
#142442 01/10/2005 6:39 PM
I thought they were too, but when I posted before about my broken spring people were saying they are not the same. Man those years pickup trucks had big hoods. I guess I will look for a regular spring.
[img]http://www.angelswest.com/_borders/dump1b.jpg[/img]
54 3100 with 235
#142443 01/10/2005 6:50 PM
Tony...send me a PM...
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
