| | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2021 Posts: 8 'Bolter | | 'Bolter Joined: Apr 2021 Posts: 8 | Has anybody ever swapped their cab onto an 80s CUCV M1008 dually? I was going to keep original frame but I’m starting to think if I swapped onto a 80’s frame I would get all the modern upgrades regarding steering and brakes. Just something I was kicking around in my head, I wonder if the chassis swap kits for C10’s would work?
1957 Chevy 3800
| | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Probably if you showed them a picture of the M1008 they might be able to answer. Not sure about the specifics but from what I understand, it may be easier in the long run to modify your existing chassis with the upgrades than to swap the cab and front clip onto a modern (ish) chassis -- lots of fab work to do that and have everything fit and work correctly. You *would* get a much beefier drivetrain, suspension and chassis with the CUCV, though ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | You may want to contact the experts at EZ Chassis Swaps at 320-226-2768 for information on your particular swap. I bought one of their kits to swap my 1956 3800 sheet metal onto a 1979 c30 chassis.
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
