1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1420975 08/17/2021 9:52 PM
Has anybody ever swapped their cab onto an 80s CUCV M1008 dually? I was going to keep original frame but I’m starting to think if I swapped onto a 80’s frame I would get all the modern upgrades regarding steering and brakes. Just something I was kicking around in my head, I wonder if the chassis swap kits for C10’s would work?
1957 Chevy 3800
62401
Probably if you showed them a picture of the M1008 they might be able to answer. Not sure about the specifics but from what I understand, it may be easier in the long run to modify your existing chassis with the upgrades than to swap the cab and front clip onto a modern (ish) chassis -- lots of fab work to do that and have everything fit and work correctly.
You *would* get a much beefier drivetrain, suspension and chassis with the CUCV, though ... wink
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
You may want to contact the experts at EZ Chassis Swaps at 320-226-2768 for information on your particular swap. I bought one of their kits to swap my 1956 3800 sheet metal onto a 1979 c30 chassis.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
Moderated by  Dusty53
