Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Peggy M, Hotrod Lincoln, Otto Skorzeny), 193 guests, and 5 robots.
Topics128,284
Posts1,058,531
Members48,490
#1416516 07/10/2021 1:47 PM
Hi Everyone!
Back with my latest project!
I picked up this 1937 1/2 ton out of Missouri and am eager to get it back on the road! It’s mostly original although it does have a more modern 235 straight 6 in it. I’ll be sourcing parts, leaving the exterior patina, while doing a period correct interior restoration. I’ll keep this one on the stock frame and do a bit of suspension and wheel adjusting to get the stance right.
Thanks for following along! You can also check it all out on Instagram (@HanerHausVintageWorks) or on Facebook (search for Haner Haus Vintage Works).
1951 Chevy 3100 1/2-Ton
"Piecing it Together - Blow by Blow"
Follow in the DITY
More photos in Flickr
1939 Chevy 3/4-Ton
In the Project Journals Forum
Hi, Just came upon your tread about you '37 Chevy.
I have been documenting the rebuilding and modernization of a '37 GMC T-14 for several months which is a very similar truck to your '37.
You might want to scroll through my tread for ideas to incorporate into your truck. Wm.
1964 C10 with Railroad cab
60-66 Forum
1940 Chevy G506 4x4
Big Bolts
1937 GMC T14
Project Journal
Nice project.....but beware, a stainless grille is not cheap! Whew!
? Offline
I will be watching closely while you go through your project. Getting ready to start on my ‘37 shortly after I get this place sold and get into my new home. Tip on buying a new home…………check out the garage first! Good luck to you. Dan
