0 members (),
89
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 30 Apprentice | | Apprentice Joined: Dec 2007 Posts: 30 | Does any know if the whole canister was black or was the bottom orange and only the top black? In the process of finding one to restore and place in my 47 half ton. Appreciate it. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | There are a few different ones, and the colors can be different. I have a NOS Fram filter in the box, I'll dig it out and post a picture for you so you can see the color combination.
Grigg | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Here is the first picture of several I just took of a genuine Fram canister type bypass filter. Click on the picture then next and next.. for the rest of them. [IMG]http://thumb9.webshots.net/t/68/68/4/94/95/2078494950080251109IriOiQ_th.jpg[/IMG]One picture shows the box with model number F-418W. It still has the original decals on it, and shows them although the top one is mostly missing. I believe that the Fram canisters can be identified by the "pleated" bottom, as other brands have a smooth bottom. I have another one installed on my truck, it looks twice as tall, not sure the brand or original color though. Grigg | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Is there a drain plug on the bottom of your canister Grigg? | | | | | Joined: Nov 2004 Posts: 2,424 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,424 | FYI: I have a couple that look just like Grigg's, so that is probably the standard color scheme.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Mazzer, if you're looking to restore yours, you can find the paint at your local auto parts store. It is called "Chevy Orange" and the decals can be purchased through most of the usual truck vendors. Jeff | | | | | Joined: Dec 2007 Posts: 30 Apprentice | | Apprentice Joined: Dec 2007 Posts: 30 | I appreciate all the help..one more question..can you tell me where the inlet and outlet lines connect in on a 216 block. I see an allen screw in what looks a port for one of the lines. It is behind and a little to the left (toward front) of the exhaust pipe. There are two other ports hooked together by a small short metal line to the right of center and near the oil gauge line. Which is which?? Mazzer | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The Fram filters were orange & black like the other bolters stated. It has a cover bolt that takes a 7/8 wrench although some use a big wing nut. The AC filter is yellow with black top. It takes a 5/8 wrench on the top bolt. The outlet behind the exhaust pipe with the tube going to the oil gauge is the pressure line. You may have to get a pipe T to hook up to it. It goes to the inlet on the side of the filter. It drains out from the bottom outlet & goes to the opening in front of the ex. pipe down near the bottom of the block. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 46 | | | | | | Joined: Jul 2016 Posts: 41 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 41 | Go to "STOVE BOLT TECH TIPS" and review the "Great Oil Filter Debate." It is a good article on GM oil filters, with pictures.
1959 Chevy Apache Stepside Truck | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | 14 year old thread by a user who hasn’t logged in to the site since 2007!
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'll make it easy for you..... https://www.stovebolt.com/techtips/engines/oil%20filters/index.html#53 I've referred to this many times with my friends. As useful today as back then, maybe even more so.
