Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
I picked up this 1937 1/2 ton out of Missouri and am eager to get it back on the road! It’s mostly original although it does have a more modern 235 straight 6 in it. I’ll be sourcing parts, leaving the exterior patina, while doing a period correct interior restoration. I’ll keep this one on the stock frame and do a bit of suspension and wheel adjusting to get the stance right.
Thanks for following along! You can also check it all out on Instagram (@HanerHausVintageWorks) or on Facebook (search for Haner Haus Vintage Works).
Hi, Just came upon your tread about you '37 Chevy. I have been documenting the rebuilding and modernization of a '37 GMC T-14 for several months which is a very similar truck to your '37. You might want to scroll through my tread for ideas to incorporate into your truck. Wm.
I will be watching closely while you go through your project. Getting ready to start on my ‘37 shortly after I get this place sold and get into my new home. Tip on buying a new home…………check out the garage first! Good luck to you. Dan
