4 members (Forty9, ShopRag, Hotrod Lincoln, 1 invisible), 118 guests, and 4 robots.
Topics128,261
Posts1,058,342
Members48,485
#1416307 07/08/2021 1:01 PM
I scaled my 53 3100. This truck is stock with the exception of a 12 bolt rear end and open driveline. No driver, no water in the radiator. I found it interesting how well balanced it is. I thought the rear would be lighter. I leveled the truck and aired the tires. These are quality race scales. This truck is like sports car balanced.
1. Total weight
2. front, rear
3. Left, right
4. Rear left, right front.
5. Right rear, left front.
Thanks, I've seen the published stats but I've been curious what they really weigh. Easy to remember: 3100 truck weighs 3150 lbs.
1951 Chevy Panel Truck
Leo Offline
Moderator
Moderator
My 1953 3100 weighed more than that. It was around 3600 pounds, don't have the tare sheet any more.
Not sure if you had a panel, burb or pickup.
heres what my '37 weighs with 1/2 tank of fuel, road ready, ( fuel tank at rear of truck )
3167 lb total LF 826, LR 795, RF 764, RR 787 ( no driver or passenger )
3580 lb total, LF 943, LR 912, RF 855, RR 860 ( driver and passenger )
It's surprisingly balanced, it too would make a a good race vehicle.
I had my truck weighed twice while leaving a landfill on scales that are not near as accurate as race scales but both times the total weight including me (roughly 200 lbs) and a set of tools behind the seat came to roughly 3400 pounds.
When people say "That heavy old truck would plow through a new car." I like to point out that most S10 pickups outweigh this "heavy old truck".
The balanced front to rear ratio explains why my truck gets around so well in snow with a decent set of tires.
An LS engine, weighing in at an easy 150 pounds less than the original 216 would almost make the truck rear heavy.
My 3/4 ton GMC says 2785lbs. Lt weight. Its painted on so it must be accurate right? Hahahahaha. I have a feeling its more in the 3400lb bracket as it sits with the LS. Now im curious. Next time I have to work at one of our plants I will get it on the scale.
......my 37 weighs 2700 with basically empty tank. (yeah, I know its light....and fast)
I had to get a cert weight for the DMV, I had 2 jack stands in the bed, I forgot were there... headscratch
It weighed 3000 lbs. exactly.
I haven't been around here in a while, is your truck on the road now mick53 ???
My stock 41 went across the dump scale with 200 pound me in it in the 3600 range. The streetrodded 46/7 went at 3660.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Moderator, Electrical Bay
About 30 years ago my 52 3100 with some gas, me, a sheet of plywood in the bed and nothing else (no spare at that time) weighed just over 3200 on the scales at a rock yard. If you've never hauled rocks in yours, they weigh you in empty, load the rocks you want and weigh you loaded (to make certain how much to charge you and so that you don't leave over-loaded).
~ Jon
Probably not an accident 3100 model comes in about 3100# .
It's not road worthy but it's complete and I drove it up to the shop. I'm getting ready to start the chassis and wanted to document my starting point. It's a complete restomod project. Street/ strip. 500 HP on pump gas and 1000 HP on race fuel. Basic 292, Falconer V-12 head (crossflow 340 CFM I, 220 CFM E) billet crank, cam and rods by Crower. 6-71 blower w/ 2 650 DP carbs. 5 stage dry sump. Electromotive T200s coil over direct fire ignition. Built Tremec TKO 600. Frankland Quick Change. Thank you for your time.
Mick, historic package for sure. Looking forward to the first dyno session and first drive!
RonR
RonR
1970 340 Duster
1964 CJ5
I'm hoping for drag week next year.
Holy mo' that is gonna be some screamin' truck! thumbs_up
My 52 1ton flatbed (how much fuel in tank?), 5200#
1952 Chevrolet 6100 2-Ton
Images in the Gallery Forum
