4 members (Chip O, Otto Skorzeny, Wayne67vert, fonz8261), 51 guests, and 4 robots.
Topics128,077
Posts1,056,016
Members48,433
#14130 04/11/2004 7:25 PM
Junior Member
Junior Member
I've read previous posts on this topic and I'm not sure which clutch to use with the 1955 261 I'm rebuilding to go into a 1953 3100 w/ 4speed. When I took the 261 from a parted out 1952 1/2T, it had a 9" clutch and 6 bolt pressure plate to a 216 flywheel. Previous posts state the 9" clutch is not adequate for the 261.
Both Jim Carter and Chevy Duty sell a 10" clutch. Is the 10"clutch my best option, and will it bolt to the 216 flywheel and fit in the 216 bellhousing?
A 10 3/4" clutch pressure plate uses 9 bolts to flywheel and LAPS sell a 11 7/8" clutch. Both would require a different flywheel and bellhousing. I've been unable to find a 10.4" clutch some previous posts have referred to.
#14131 04/11/2004 10:16 PM
What are you going to do with the truck? If you're just going to cruise I would go with the lightest clutch possible. Heavy duty clutches are hard to disengage and hold in stop and go traffic. I wouldn't go too crazy with a heavy clutch in a 1/2 ton, make it fun to drive. Besides, how hard is it to change the clutch if it only lasts a couple of years anyway?
Just my 2 cents worth,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#14132 04/12/2004 12:00 AM
The clutch that was in my '48 with 4 speed was 10 3/4" in diameter. My clutch shop had a new one hanging on the wall so that's what I used behind my new 261.
#14133 04/12/2004 12:34 AM
knuckle head
knuckle head
I have a 50 Chevy 6 with a 10.4 diagpram unit used by all small block V-8's
#14134 04/13/2004 3:01 AM
Junior Member
Junior Member
Thanks for the input. I have three flywheels for the 9 1/8" clutch, so unless I find a larger flywheel, I'll have the engine balanced with the smaller clutch. I'll get everything reassembled for cruising around town and worry about a larger clutch later.
