0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 31 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 31 | Does anyone know of a rebuild kit for the gears in the windshield crank on a 37 chevy?? | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I am not aware of a do-it-yourself rebuild kit. Based on my experience with my '42 and '37, as the mechanism wears, the steel axle of the wheel that moves the tongue wallows out the hole in the aluminum body. This causes the gears to not mesh properly and causes wear of the gears. To restore the assembly you have to start with fixing that wallowed out hole in the body.
A friend help fix the mechanism of my '42 by making an aluminum bushing for the axle and then milling a hole for the bushing in the body. We couldn't do much for the wear on the gears but it re-aligned the gears so they now mesh properly and the crank functions much better. There is still a little slop in the crank due to the previous wear of the gears.
If you search the internet you will find restored assemblies on Ebay, as well as someone who has made new aluminum castings of the body. I don't know if either one makes new gear sets. Kent | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | It is here somewhere.....or over on the VCCA site of a fellow who is reproducing them. I may have seen the ad in the VCCA magazine with the info......but pricey. I think they are asking around 425 for a complete new unit. | | | | | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | | | |
